^Nytro^ Posted August 8, 2003 Report Share Posted August 8, 2003 I have wondered whether it is possible andor recommanded to start working with sonicstage instead of the older OMG though my program is normally OpenMG. What's SonicStage's advantages over the OMG? will the program work with my MZ-N1 device? thanx>< Quote Link to comment Share on other sites More sharing options...
sudden Posted August 8, 2003 Report Share Posted August 8, 2003 Why bother with either OpenMG or SonicStage when you can do it with M3U2Sburner/Simple Burner? With those proggies you don't have the nagging check in/out crap. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted August 9, 2003 Report Share Posted August 9, 2003 the point that sudden has brought up is an important one since openmg and sonicstage are annoying...but 2 answer your q, yes the n1 can be used with sonicstage (i'm doing this on my laptop) and whether you want to use sonicstage over openmg is entirely up to u...sonicstage 1.5 seems to need more clicks to get things done as compared with openmg 2.2...but both do exactly the same thing (and both hav similar flaws)... Quote Link to comment Share on other sites More sharing options...
^Nytro^ Posted August 9, 2003 Author Report Share Posted August 9, 2003 My thanks to all, you've kinda convinced me to use the Simple Burner though the problem is that it can burn from CDs only as far as I know and I dont have any CDs from which I want to burn MDs, most of the tracks are on my PC. So, i'll currently stick to OMG, I guess. thanx>+< Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted August 9, 2003 Report Share Posted August 9, 2003 u could use the Nero/SimpleBurner trick that has been posted up here...using nero to compile your tracks and save as an image on ur hdd, which with image drive (included with nero) can mount as a virtual drive, simpleburner can use that drive as if there were a compiled audio CD inserted in2 it... Quote Link to comment Share on other sites More sharing options...
sudden Posted August 9, 2003 Report Share Posted August 9, 2003 If you don't have Nero I recomend Daemon Tools (www.daemon-tools.cc). That program can emulate a CD unit and mount any bin cue image files. Btw it's freeware. First use M3U2Sburner (http://members.xoom.virgilio.it/paolose/) to make your playlist out of mp3. Make a Audio CD image with it and then mount it with Daemon Tools. Open SimpleBurner and presto! You can make a NetMD disc from that sourse. Basically it the same process as with Nero but the beuty of this is that M3U2Sburner have all the steps in it and best part, it names tracks after mp3 id tag. Quote Link to comment Share on other sites More sharing options...
