cant mark tracks on md
Guest Anonymous
Guest Anonymous
i recenty got a live session of paul van dyke playing at a club and downloaded it and transfered to my sony mz-n505 ...but its coming up as 1 track of 70mins
ive tried putting markers in but it wont do anything
am i doning anything wrong or leaving something out?
paul van dyk mixes usually go on for this amount of time i would think (becoz all of the one's i've got do) and if u transfer the song directly to the NetMD then it should show up as one whole track (unless u transfered the song in seperate files...) but otherwise you can do a manual trackmark where ever you wanted them (either on the unit or on the PC)...then transfer it again...it should work...
Guest Anonymous
ive done all that, even the bit in the instructions showing you what to do but it just wont save any markers
im looking to make one every 5mins so i dont have to start at the same spot each time i play the MD
on the mz-n505 i hit T-MARK and on the screen it says SAVED, but when i try to fast forward or rewind i go back to the start of teh MD sad.gif
hmmm...that's odd...did u try and chop the song up on the PC instead??? like making a bunch of 5 minute tracks and transfering??? because this is the only other alternative...i'll try and give ur problem a go on my N1 unit when i get home and c if i can do a track mark every 5 or so minutes on the song...i'll keep you posted when i try it out l8r...
