Guest Anonymous Posted August 27, 2003 Report Share Posted August 27, 2003 Just looking at the service guide for the MZ-N707 (http://www.minidisc.org/manuals/sony/service/sony_MZ-N707_service_manual.pdf), the pin assignation table on page 52 lists two interesting entries: pin 191-193: D/A converter PWM signal output terminal - not used pin 194: Audio data output terminal - not used Does the "not used" mean that the function is not present, or simply that the output signal is present but not used by any subsequent process? Has anyone tried connecting either of these outputs to an external DAC? Quote Link to comment Share on other sites More sharing options...
steelydoubt Posted August 30, 2003 Report Share Posted August 30, 2003 i think the md port has a chip in it that adds a header to the digital signal coming from another chip. i would try it but i dont have an md port. Quote Link to comment Share on other sites More sharing options...
steelydoubt Posted September 2, 2003 Report Share Posted September 2, 2003 the new sharp has actual digital output, but only on the charging cradle. although thay may have an adapter for digital output on the go. Quote Link to comment Share on other sites More sharing options...
thinkmd Posted January 24, 2004 Report Share Posted January 24, 2004 the new sharp has actual digital output, but only on the charging cradle. although thay may have an adapter for digital output on the go.Steely, PLEASE, PLEASE post the appropriate model number(s) for the Sharp and/or cradle that you mention here. There are MANY folks (myself included) who would LOVE to do DIGITAL MD-->PC transfers. (This is, in fact why I got my MD in the first place!!) This very weekend, in fact, I am trying to pull together a transfer scenario that will work. I would LOVE to be able to take my N707 back for a refund and get the Sharp if I knew that the Sharp would do the trick for me. What did you mean when you said, they may have an adapter for digital output on the go? Do you mean that you'd be able (with said adapter) to do digital output (from the MD) without having to use the cradle? (Any word on the "unused data" pins mentioned here?) ** THANKS SO MUCH IN ADVANCE, STEELY!!! ** Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted January 25, 2004 Report Share Posted January 25, 2004 i didn't know the DR580's cradle had a digital out...last time i checked they took it out...??? Quote Link to comment Share on other sites More sharing options...
