Guest Anonymous Posted October 23, 2003 Report Share Posted October 23, 2003 I hacked my MZ-R700 and now there seems to be lots of problems with it which include: 1. I can't charge the battery (it just makes a clicking sound everytime i press charge) 2. Whenever the unit automatically shuts off, it makes a weird clicking sound 3. It never shows the "no disc" message. If anyone know how to fix this I would really appreciate it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 29, 2003 Report Share Posted October 29, 2003 Well, sorry mate, but you knew the risks involved... anyway, all you can do is go to a registered Sony dealership/ repair centre really. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 29, 2003 Report Share Posted October 29, 2003 either u take it 2 a Sony repair store or try and "un-hack" ur unit to its previous settings to see if that works... Quote Link to comment Share on other sites More sharing options...
bertrik Posted October 29, 2003 Report Share Posted October 29, 2003 You could try to set back the original values of the F-code registers that you changed (if you still remember them / wrote them down). If you don't know the original values, it may help to set f-code 63 from 1 to 0. On my MZ-N510 this sets f-code registers 61 and 62 back to their original values. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 2, 2003 Report Share Posted November 2, 2003 I tried to set the F-codes back to the original but the problems are still there...i even reset the EEPROM with the guide but that didnt work either. Oh well I guess i'm stuck with an MD that won't charge its battery. At least I learnt my lesson about not messing with firmware settings Thanks for ur replies. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 2, 2003 Report Share Posted November 2, 2003 Messing with firmware is harmless when the instructions are followed to a T. Not that I'd bother to hack my R500, but my RioVolt is running on iRiver firmware. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2003 Report Share Posted November 5, 2003 I'm pretty sure that I followed the guide properly. I did some searching and it seems that i'm not the only one that this has happened to check these threads out. http://forums.minidisc.org/viewtopic.php?t=181 http://forums.minidisc.org/viewtopic.php?t=153 Quote Link to comment Share on other sites More sharing options...
