BerkY Posted November 25, 2003 Report Share Posted November 25, 2003 Hi ppl! Ok here is a simple question... I bought the N910, which I am totally satisfied with. I also bought a 5-pack of MDs that came in 5 differnet colours, MD COLOR or whatever it is... I have used them all up so i need a new pack of MDs... What i want to know is what you guys are using and what you think I should be using... I mainly record music from the computer using sonicstage and they are mainly hip hop, r&b or techno style of music. I have seen that sony has lots of media types like the bianca, prism, lumina and heaps others... oh and the color ones that i bought. Which one should i buy? What do you suggest? Which ones are better than others? Which ones have an anti- shock mechanism (i presume all of them do but i had to ask...) Thanks in advance. Cheers BerkY Quote Link to comment Share on other sites More sharing options...
BerkY Posted November 25, 2003 Author Report Share Posted November 25, 2003 Sorry guys didnt see the media forum... However, it doesnt fully answer my question... So should i buy just anything i can get my hands on or just sony, tdk etc... I mean I want to know that difference is between all the Sony medias since they have heaps. Are they all the same? Cheers BerkY PS: I never thought i'd be replying to my own post... LOL Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted November 26, 2003 Report Share Posted November 26, 2003 colour ones are fine for everyday recording sessions...personally i use the Sony Prisms, Neige and ES series...i'm about to get a few MD2000 blanks and test out the quality of them as well...but the majority of my MD's come from those three and the colour series from different companies...the ES ones are meant to be Sony's highest grade of quality media and is reserved for high quality recordings since they'r slightly more expensive... Quote Link to comment Share on other sites More sharing options...
BerkY Posted November 27, 2003 Author Report Share Posted November 27, 2003 Ok mate thanks... I think here in europe, it is hard to find all sorts of sony media but i am going to look for it. In Turkey it seems impossible as only official sony stores seem to have them which is totally crap! In australia it is a lot easier though. Anyway I'll see what I can do. Probably going to go for what I can find which seems like the color series and the ES series... Cheers BerkY Quote Link to comment Share on other sites More sharing options...
