Cannot Transfer
Guest Anonymous
Guest Anonymous
Sorry if this if the wrong forum.
I connected my ND to the line-in on my PC to record what I had got off my DVD and it won't record. I've tried all the jacks on the back of the soundcard but it don't want to record anything. Maybe my soundcard just cannot record?
My SC is a Creative Audio ES1371/1373 (WDM)
Any suggestions?
use the Creative Recorder software that came bundled with your soundcard and see if it can detect the levels of the input...also try taking alook in the Volume control panel and check that all your input ports are at full volume level and unmuted (just to see if any signal goes through) and again check the levels of the LINE IN of the card from Creative's Recorder and then try playback something as a test to see if the VU meters move at all...
