trouble with mz-nf610
Guest Anonymous
Guest Anonymous
hey
when i want to transfer songs to my netmd (mz-nf610) it says the following:
with sonicstage:
error while converting the data
with netmd simple burner:
error reading audio cd
with realone player:
make sure there is enough space on the disc and that the format of the file is supported.
:shock: so what is the real problem now? plz plz help or ill have to record with the analog line :x HEEEEELPPP!
sound like there's an error with the songs or the software...if a blank MD is inserted and this happens then check if you can transfer another song (as a test) across via those programs...if not then it could be either the software or the song...try encoding it to a .wav file with LAME and see if you can transfer across because this works most of the time...if it can't then it's a problem with your software and you need to reinstall your software and drivers to see if this can fix up the problem (this usually works)...
Guest Anonymous
well yea i tried all that but its not working. for some reason sonicstage displays checkout remaining as 0 even for new songs :evil: even after reinstall. for some reason that thing has changed... i really dont wanna format my hdd again (that worked once) so is there a method of resetting this counter? i read this thing about the database clearing the field 205 but it didnt work sad.gif so what do i do now???????????
HEEEEELLLPP!!!
ps: i even tried the dino trick with nero+imagedrive but with the same result. apart from that nero cant handle rmj files is there a plug in or another way of doing that?
Guest Anonymous
yea thats what i tried but it didnt work... and even new songs cant be transferred. sonicstage now always wants to start this backup prog thing but since i didnt make that backup its useless.
any idea?
Guest Anonymous
yea that sux
an yone knows a software that doesnt depend on sonicstage in any way and doesnt need drm or something? cuz simpleburner and realone player use it in some way., any help would be greatly appreciated as i dont wanna format my hdd again... :roll:
