Guest Anonymous Posted December 15, 2003 Report Share Posted December 15, 2003 Does anyone know where I can download Sonic Stage 1.5 or Open MG 2.2 on the web ?? Thanks folks.... Quote Link to comment Share on other sites More sharing options...
JeffS Posted December 15, 2003 Report Share Posted December 15, 2003 yup, head over to sonystyle.com look under the support section for minidiscs. you can download the apps there. Sorry I don't remember the exact address. Sony should be sorry for making their site so complicated to navigate. Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 15, 2003 Report Share Posted December 15, 2003 Arent they only updates??? Dont you need the program to be installed before hand? Though his address might help... http://www.support-nwwalkman.com/uk/default.asp Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 16, 2003 Report Share Posted December 16, 2003 guys, i checked the sites you told me but unfortunately there are only updates to download... Can anyone tell me how to get the ORIGINAL SonicStage 1.5 program or OpenMG 2.2 ??? Many thanks..... Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted December 16, 2003 Report Share Posted December 16, 2003 try here... Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 17, 2003 Report Share Posted December 17, 2003 The site i wrote about has the file and it even though it seems like an update it is the FULL program... Cheers BerkY Quote Link to comment Share on other sites More sharing options...
Bazirker Posted December 18, 2003 Report Share Posted December 18, 2003 Yeah, I think Berky's right. Look at the file size, it's way too big to just be an update. However, if you read the stickies, you would've quickly and easily found this link: http://www.my-minidisc.com/download.html I suggest installing Sonicstage, then Simple Burner, then just using Dino's method instead of Sonicstage. Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 20, 2003 Report Share Posted December 20, 2003 I can give you a guarantee that IT IS a FULL program... I've downloaded it Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted December 20, 2003 Report Share Posted December 20, 2003 a few users have commented about this prior to your post i think and yes i can also say that the file is NOT an update since i've d/l it and installed it as well... Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 20, 2003 Report Share Posted December 20, 2003 So its confirmed then, eh? Quote Link to comment Share on other sites More sharing options...
