Guest Anonymous Posted December 27, 2003 Report Share Posted December 27, 2003 Hey ppl, just a couple of questions 1. How do you access the menu from the remote?? 2. Where is music uploaded via Sonicstage stored??? 3. When you press the "sound" button it switches between (1) normal sound, (2) surround sound and (3) sound equaliser. But there should be several options under both (2) and (3), how do you switch between them? thanks Quote Link to comment Share on other sites More sharing options...
BerkY Posted December 28, 2003 Report Share Posted December 28, 2003 1. You press DISPLAY on the remote for 2 seconds and the menu comes up... 2. It is stored under PACKAGES in the default directory (C:Program FilesSonyPackages) 3. You press and hold the SOUND button while SURROUND SOUND or SOUND EQUALISER settings are activated. And you can choose with the FORWARD or REWIND buttons... When you choose one, you have to press PLAY... and voila btw next time please take a look at the manual... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2003 Report Share Posted December 28, 2003 thanks for your help. I tried to locate the C:Program FilesSonyPackages directory but couldnt. Under Sony there is only Sonicsatge, Open MG and Net MD Driver, and it isnt under any of them Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted December 28, 2003 Report Share Posted December 28, 2003 you can find where the OpenMG/SonicStage puts the .omg files : For SonicStage : by just clicking on the Menu button on the bottom left then go to Options...from there there should be an option on the left box called Location to save the recorded files...clicking on that will show you where SonicStage puts them....just copy and paste that directory into Windows Explorer and go to that directory and delete all the .omg files there... For OpenMG : this is a similar method since OpenMG and SonicStage are essentially the same program just with a different GUI (though OpenMG 2.2 and SonicStage 1.2 look exactly alike...) Go to the menu on the top bar called Tools then Options the from there a box will pop up with a few tabs on the top...clicking on the one named CD Recording/Playing 1 and going about 1/2 down the screen you will see an option called Settings for CD Recording and below that a box where it tells you the Location to save the recorded file...copy and paste this in Windows Explorer to open up the directory and delete the .omg files... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2003 Report Share Posted December 28, 2003 thanks, and one last question!! Can you have an album recoreded in LP4 and one recorded in LP2 on the same disc???? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted December 28, 2003 Report Share Posted December 28, 2003 yep Quote Link to comment Share on other sites More sharing options...
