netmd n510
daz
sad.gif I can any one help i got my son a sony n510 for xmas.
I was playing fine he tryed to record thruogh the optical cable from the dvd player on my stereo which seemed to be going ok .
But when it ad finished recording it wont play back on his md the disk spins tells you the amount on disk but no sound.
i would be grtfull for any advice as he says hes not olterd the menu at all.
thanks daz
  • 3 months later...
that's not always true...it depends if the dvd player and the cd/dvd played is actually protected...if so it won't let you copy...if not then it usually is fine...i've had no problems recording from my DVD player (with the exception of some CD/DVD's which are protected and won't allow me to copy digitally)
