HiMD units recording capabilities
pata2001
From what I read form the FAQ, it seems that HiMD units cannot record old SP format in realtime. Older LP format (atrac3 based) can only be recorded via USB, not realtime. This really limits the "backward compatibility" of HiMD, except that it could play the old formats. When MDLP was introduced, at least the new recorders can still record in SP mode.
Also, can HiMD units record to an old MD media without reformatting it?
If the newer units cannot record in the old format without reformatting the old media, this means that HiMD could make MD units (especially the player only units) obselete as HiMD units can play everything, but their recordings cannot be read by older MD units (with the exception maybe the LAM-X1). Bummer, especially for newcomers like me. sad.gif
When MDLP and NetMD were introduced, at least the recorders can still record in SP mode for backward compatibility with older non-MDLP units. Hopefully Sony would think about this in the 2nd gen HiMD units.
  • 1 month later...
I don't see that as being an issue, unless you have friends who also use MDs and like to lend them back and forth, which isn't so likely. I'm sure you'll still be able to buy the MD blanks online for many years to come. With me I don't plan on getting Hi-MD anytime soon, if ever, but I don't think that'll have any effect on being an MD user.
These questions have now been answered by the folks at MDCenter.nl.
http://www.minidisc.org/himd_mdcenter_news.html
Here's the basics, what I've gleaned from the write-up as well as my conversation with one of the MDCenter team (MDFreak):
The units themselves can record the following in real time:
To old MD media, not reformatted to Hi-MD:
SP, SP Mono, LP2, LP4
(so yes, you can record on a non-Hi-MD formatted disc in either real time on the unit or by sending it LP2 / LP4 tracks in NetMD mode in Sonic Stage)
To old MD media reformatted to Hi-MD format, as well as 1GB Hi-MD media:
Linear PCM, Hi-SP, Hi-LP (no mono)
(SP, Lp2, and Lp4 cannot be recorded in real time to Hi-MD formatted media. However, LP2, LP4, and psuedo SP (LP2 badged as SP) can be transferred to Hi-MD formatted discs).
In short, new Hi-MD units can function such that the discs they produce are fully backwards compatible with older MDLP units.
