Guest Anonymous Posted February 22, 2004 Report Share Posted February 22, 2004 hi,do u know how can i connect my MD (MZ-R909) to my stereo and use its speakers ?? i have an optic cable and a line out but the problem is the stereo doesnt have an optic out ...thnx for ur help Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted February 22, 2004 Report Share Posted February 22, 2004 so u want to go from ur MD unit -> HiFi to use its speakers right? well i think the R909 features a LINE OUT on it so u run a normal 3.5mm stereo cable from the LINE OUT of the R909 to the LINE IN on your HiFi...provided that your HiFi has a LINE IN (usually in RCA so u need a cable that splits it from a normal 3.5mm stereo -> RCA Audio cable) and go to the HiFi and select the Aux mode or something similar to get sound from it... Quote Link to comment Share on other sites More sharing options...
darkfusion Posted February 22, 2004 Report Share Posted February 22, 2004 If you're going to be feeding the MD into an RCA input I found the Profigold PGA3402 to be pretty good and it can be had for as little as £10 - £15. Alternativly you can pick up a Mini > RCA adapter for $5 and then use any RCA cables you want. The mini to rca adapter can be bought here: ]http://www.headphone.com/layout.php?topicI...060260005 Quote Link to comment Share on other sites More sharing options...
