Shepherd Posted March 16, 2004 Report Share Posted March 16, 2004 Hi all, Lots of questions here! Just picked up a cheap N510 on eBay, but it's just the unit -- no cables, no remote, no nothin' else. And that's fine -- I never used the remote on my R900 that much, and I don't mind a slower record transfer through the line/opt in. I have some variable power adapters for recharging, and I have better headphones and an optical cable and USB optical adapter from the R900 too. I'm not sure, though, of two things: 1. Does the N510 just use a traditional USB cable, or would I need some fancy-dan USB cable to use NetMD? 2. Is Sonicstage/Simple Burner downloadable anywhere? If the USB cable is normal and SonicStage can be downloaded, I'll probably just stick to the existing N510. If I need special USB cables and getting SonicStage/Simple Burner would be a major pain, I'll probably wait until I can pick up another unit. Which brings on the second question: Is the paraphenalia on the R410 or the Aiwa NX9 transferable to the N510? If I could pick up a cheaper "jukebox" for my girlfriend, which is all she wants, and be able to share the - power adapter - software and - USB cabling, that would be great. Thanks, all! - Matt Quote Link to comment Share on other sites More sharing options...
Shepherd Posted March 16, 2004 Author Report Share Posted March 16, 2004 Ut! Think I found SonicStage. The other questions still apply, though: - is the USB cable I need for the 510 just vanilla, or is there some fancy doohickey I'll require? - can I use the accessories from a 410 or an Aiwa NX9 with an N510 -- power adapter, USB cable, software? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted March 17, 2004 Report Share Posted March 17, 2004 the USB cable is nothing proprietary on the 510...just use a cable that will fit the socket on the unit (like the digital camera USB cables)...the power adaptor i would say yes IF the specs match up...as with USB cable...and software yup so long as it's from Sony go ahead...otherwise u can use RealOne or something to transfer over via USB as an alternative.... Quote Link to comment Share on other sites More sharing options...
Shepherd Posted March 22, 2004 Author Report Share Posted March 22, 2004 Poop! I misunderstood your post -- I DO need a special KIND of USB cable, don't I! The 510 arrived today, and it needs a l'il connector at one end, which is unfortunately different than the USB cable for our Kodak digital camera. Any idea where I could buy one online? Bonus points for CANADIAN locations! - Matt Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted March 25, 2004 Report Share Posted March 25, 2004 not too sure about canadian locations but i'm sure that u could probably go down to one of the computer/photography stores over there they'd stock one of those cables as a replacement? otherwise u can check online at Japan-Direct, Audio Cubes or Minidisco and see if they have any... Quote Link to comment Share on other sites More sharing options...
