sony_man Posted March 27, 2004 Report Share Posted March 27, 2004 has anyone ever tried to make a non back- lit remote a back- lit one by modifying it? Quote Link to comment Share on other sites More sharing options...
Christopher Posted March 28, 2004 Report Share Posted March 28, 2004 This is a very difficult task that I've never heard of anyone accomplishing. I suggest you look into purchasing a backlit remote off eBay, since they're quite cheap these days. Technically, you'd probably need a few things soldered onto the circuit board on the remote, and in the process making sure that you don't make the insides larger than the case holding it. Quote Link to comment Share on other sites More sharing options...
sony_man Posted March 29, 2004 Author Report Share Posted March 29, 2004 well ok then ill just stick an led light on the front then :grin: Quote Link to comment Share on other sites More sharing options...
