hc_spooky Posted June 9, 2004 Report Share Posted June 9, 2004 I did read the service manual for this unit. I've played in the Test/Manual Mode and I guess I screwed it up. I did reset my NV settings. When I turn the unit on I get only Error message. I still can enter the Test Mode and Manual Mode Any help how to get the unit work again ? Patch Writer or NV Writer would maybe help...or any other idea ? thanks! val. Quote Link to comment Share on other sites More sharing options...
Pimp924 Posted March 23, 2011 Report Share Posted March 23, 2011 Maybe you like something to help this forum http://www.minidiscf...20081&view=next Quote Link to comment Share on other sites More sharing options...
sfbp Posted March 23, 2011 Report Share Posted March 23, 2011 On 6/9/2004 at 2:33 AM, hc_spooky said: I did read the service manual for this unit. I've played in the Test/Manual Mode and I guess I screwed it up. I did reset my NV settings. When I turn the unit on I get only Error message. I still can enter the Test Mode and Manual Mode Any help how to get the unit work again ? Patch Writer or NV Writer would maybe help...or any other idea ? thanks! val. You need to follow the alignment procedure. You will need 1 pre-mastered, non-writeable MD (any will do, this is referred to as a "CD" in the jargon) and one blank standard MD ("MO"). The alignment procedure will recalculate all the servo parameters. It's possible to completely ignore it but definitely not recommended. If you need to you can send to someone. There a couple of people here who may be able to help. PS.. the patchwriter won't actually help you, it has to do with NetMD mostly. Here it is anyway http://esi.sony.ca/esupport/esupport/NetMD/MZ-N10/ Quote Link to comment Share on other sites More sharing options...
