Uploading PCM recordings
Paula
so, you are able to upload recordings made from mic (or other input)? i thought that you could only re-capture in realtime. and if you can upload from player to pc, is it only pcm or does it work for any compression? will it work with older units or just hi-md?
this is only iceeeedteas version too, right?
p.s. i registered just for this question :smile:
Upload is possible for all recordings done with a Hi-MD recorder done in Hi-MD mode done via Mic/Line/Digital In.
Hi-MD mode means LinearPCM/Hi-SP/Hi-LP.
Of course, you have to use a Hi-MD unit for upload as well.
Old NetMD-Recorders cannot upload.
Recordings done on old equipment or made in NetMD-mode cannot be uploaded.
The NetMD-mode creates discs compatible to old equipment.
Uploading can be done in two ways:
Playback via USB and rerecording with a wave-recording software (Realtime) or
via the supplied SonicStage software (Much faster).
you can use the commercial version to upload your recorded material... but you can't export it (currently) to a cd, unless you have a VAIO computer (GOD i hate sony's proprietary crap)
iceedtea's build of SS2 bypasses the "VAIO check" and lets any computer burn cd's via SS2.
