The Bends Posted June 18, 2004 Report Share Posted June 18, 2004 I am having a tough time getting my head around the possibilities of the new hi-md format. I have historically used minidisc to record cd's optically through a cd player and recorde the occasional live show. I am excited about the new format. I plan on using it to transfer files from wok to home as well as for the music. I am planning on getting the top o the line mainly for the smaller size and the promise of a the nice remote. I was salivating over the mz-e10 player for the size, but this model is close to the size and can hold so much music. What would be the best way to get high quality (LP2-ish) music to my Hi-Md and allow for the most music on a single disc? Quote Link to comment Share on other sites More sharing options...
mutant1345 Posted June 18, 2004 Report Share Posted June 18, 2004 probly in 64kbps in atrac3+ unless you have a very very precise ear or you are doing live recording or line in recording because this makes the difference in sound very nnoticible so i would use a higher bitrate for anything except USB for music Quote Link to comment Share on other sites More sharing options...
Leland Posted June 18, 2004 Report Share Posted June 18, 2004 My experience with ATRAC 3 plus at 64 kbps is disappointing. I would recommend the higher bit rate HI-SP mode. Quote Link to comment Share on other sites More sharing options...
Leland Posted June 20, 2004 Report Share Posted June 20, 2004 One other thought, you can still rip your CD's at ATRAC3 132 (LP2) and simply use that. Actually, with HiMD, you can avoid ATRAC3plus altogether if you want to. Since I found the quality of Hi-LP to be too low and the compression of Hi-SP to be to little, I would probably use this strategy. That way your database is compatible with Net MD too, in case that was ever needed. Quote Link to comment Share on other sites More sharing options...
