Alternatives to SS and OpenMG?
Hi avid MD fans
Im not sure if this question has been asked before, and if it has, excuse me for i am new, but is there any alternatives out there for Sonicstage and OpemMG? I uterly dislike both programs and am wondering is there something out there that is actually, "user friendly".
Any contribution would really be appreciated
Abe
  • 3 weeks later...
1)where can i get the update to ss1.5
i wanna get the2 or 2.1 version but the connect.com service aint available in Portugal and all the say is that "We will keep you updated" sad.gif but no proggie sad.gif
2)No limitations in number of transfers from 2.0 version?
3)Whats the dif between 2.0 e 2.1 ?
Thankx
  • 5 weeks later...
if your just using netmd, you can use real player 10, which you can configure to delete the openMG file once its transfered, which is nice.
if you're using hi-md, your stuck with sonicstage for now...
Last time I used RP10, it gave the (grayed out) option to transfer files to a NetMD in Hi-SP and Hi-LP, in addition to the available LP2 and LP4. It seems to me that RP 10 would work with HIMD upon installing the required codecs and drivers. ( I had SS 2.0 installed at the time)
