PhiLiXer 0 Posted February 19 Report Share Posted February 19 Hey guys, I lastly listen music on my Sony Walkman D-NE711, and I think that remote will be good buy, but idk which model i should buy. Can you help me guys? [EDIT] I have read this topic but i not found my player. But very similar model is D-NE720, and remote for it is RM-MC53EL. Can I buy it and sleep soundly? Quote Link to post Share on other sites
slugbahr 6 Posted February 20 Report Share Posted February 20 It should be fine. But I can't say for sure. It is very strange that your unit doesn't come with a remote in the box. The 38el remote might be good enough as well, and a lot cheaper and easier to find. Quote Link to post Share on other sites
Richard 0 Posted February 20 Report Share Posted February 20 I concur - I think the 53EL / 55ELK or 38EL should all work fine. I am not familiar with the NE711, but I guess perhaps it was a Europe only model. Strange indeed that it has the remote port, but no remote bundled.. Quote Link to post Share on other sites
PhiLiXer 0 Posted February 21 Author Report Share Posted February 21 Yes, my model don't have remote in box. Can I use 53EL or 38EL when it has remote port??? Quote Link to post Share on other sites
Richard 0 Posted February 21 Report Share Posted February 21 1 hour ago, PhiLiXer said: Yes, my model don't have remote in box. Can I use 53EL or 38EL when it has remote port??? Yes, the remote port is a common standard across all players Quote Link to post Share on other sites
PhiLiXer 0 Posted February 21 Author Report Share Posted February 21 Ok, thank you very much guys. Quote Link to post Share on other sites
