mac dre Posted February 16, 2005 Report Share Posted February 16, 2005 Hi im new to the MD world so i just got a couple of questions, my friend is telling me to buy a md player and is recomending this one Sony MZNH600D Hi-MD MiniDisc Walkman. i woul djust be using my md player for listing to music not recording anything. my questions are: 1) is that a good md player2) would i be able to run with this at the gym/street? (if i would use it at the gym it wouldnt be straped on my arm it would just sit in a cup holder on the treadmill)and i think thats about it any help would be much appreciated. thnx Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted February 16, 2005 Report Share Posted February 16, 2005 just for simple listening to music and not being to desperate for features the 600 is for you. Actually, correct me if im wrong, but does the 600D have the opt in or does the 600? im so confused. anyways this is the entry level HiMD player and thus doesnt have all of the features and compared to the other units isnt the best looking/feeling HOWEVER with that said, the playback abilities of this unit are on par with the others and is probably perfect for your reasonds.its runs on AAs and all HiMD units have a memory buffer that should enabled unlimited antishock (i have owned two MD units over the past 3 years and i have never heard a MD skip)so all in all for a smaller budget and a person who wants to enjoy HiMD but only listen to music this is probably your best bet Quote Link to comment Share on other sites More sharing options...
Damage Posted February 16, 2005 Report Share Posted February 16, 2005 (edited) 1) If you can find it under the MSRP of $200, then yes. Sams Club has the unit, 5 normal MD blanks, and an armstrap for $130. The US 600D is download only and has only USB port. The Canadien/European/World model has a line-in, handy for recording from Radio or anywhere else, these are denoted by the lack of the trailing D, and should be easily obtained on the net.2) It normally won't skip when left alone. However, under heavy physical motion with lots of tracks, it has been known to skip a bit when you're playing the disc in shuffle mode. There are also batches of disc suspected to be somewhat... suspect during transfers. Whether or not it's a small batch or two or a wide spread problem is unknown. I've ran into this when transferring a large number of files in one sitting along with others (read some older posts and you'll see). Edited February 16, 2005 by Damage Quote Link to comment Share on other sites More sharing options...
mac dre Posted February 16, 2005 Author Report Share Posted February 16, 2005 so i can run with this and nothing will happen to it? wonders why i havent had a md years ago... Quote Link to comment Share on other sites More sharing options...
roguefan99 Posted February 16, 2005 Report Share Posted February 16, 2005 (edited) I have mine (600 model not the 600D) in my backpack, in the "ipod holder". I've sprant (probably not the word but sprint doesn't sound right) after the bus with my bag bouncing around (a fair shock I would say) and it didn't jump. I had it skip once and that was a sliding impact shock (it spun me around, yes I'm a maniac that usually ends up running for the bus), but not 100% sure it was the MD that gave the skip or my headphones/remote having a wiring dummy spit.Now that you have a 1Gb model its probably a good thing to go for, a heap of tracks on there and you can shuffle between them or set up groups. Edited February 16, 2005 by roguefan99 Quote Link to comment Share on other sites More sharing options...
mac dre Posted February 16, 2005 Author Report Share Posted February 16, 2005 (edited) so i shouldnt have any worries with runnin with this at all? just makin sure lol becuase like i said imma be using this for like 30 mins every day on a treadmill and the rest just sittin in my pocket in class or at home? any one else have any experience of info before i make my decision? Edited February 16, 2005 by mac dre Quote Link to comment Share on other sites More sharing options...
aeriyn Posted February 16, 2005 Report Share Posted February 16, 2005 Cori's Standard Advice: If you are not going to record or do not already own lots of MDs and MD related equipment, MD is not for you.That said, if you don't mind how big the thing is, the NH600D can actually be found cheaply enough online that it's somewhat worth it. But I'd recommend saving up for a high quality DAP; it'll last you for many years. Quote Link to comment Share on other sites More sharing options...
Michael1980 Posted February 16, 2005 Report Share Posted February 16, 2005 I recommend a cheap recorder and the most expensive player you can find. Quote Link to comment Share on other sites More sharing options...
aeriyn Posted February 16, 2005 Report Share Posted February 16, 2005 Michael1980 said: I recommend a cheap recorder and the most expensive player you can find. ←Hahaha, that was my philosophy when I was an MD head. MDS-JE630 deck ($110 US) paired with a Sharp MD-DS8 portable player ($125 US). That was my setup. Quote Link to comment Share on other sites More sharing options...
Fast Eddie Posted February 16, 2005 Report Share Posted February 16, 2005 Yep, 600D all the way. You can't go wrong. Minidisc is still the best econonically portable music system on the market today. Quote Link to comment Share on other sites More sharing options...
aeriyn Posted February 16, 2005 Report Share Posted February 16, 2005 Fast Eddie said: Yep, 600D all the way. You can't go wrong. Minidisc is still the best econonically portable music system on the market today.←Good point, so long as you don't pay retail price.If you want the best possible sound quality, the HDD players take the lead there. But if you're strapped for cash and need some skip=free tunes that sound reasonably good, MD isn't a bad choice. Actually, if I was in desperate need of a portable unit, I'd go buy me an older MD player. The insurgence of Hi-MD has caused their value to plummet, and they're going for practically nothing on eBay. I see R900s for 70 bucks now... when I actively used mine before it died, they were still twice that much on eBay. Quote Link to comment Share on other sites More sharing options...
