Guest tony wong Posted March 13, 2005 Report Share Posted March 13, 2005 (edited) 1. can it record(line in) in MD mode?2. how about transferring MD mode songs from computer to it in MD mode?well, we can say there is rumourswe need to confirm on that, pls[added]in red Edited March 13, 2005 by tony wong Quote Link to comment Share on other sites More sharing options...
Michael1980 Posted March 13, 2005 Report Share Posted March 13, 2005 1. No2. I don't know for sure, but I would say yes. Quote Link to comment Share on other sites More sharing options...
Guest tony wong Posted March 13, 2005 Report Share Posted March 13, 2005 Michael1980 said: 1. No2. I don't know for sure, but I would say yes.←oh so u r the next member who DO have a 2nd gen Hi-MD unit now? Quote Link to comment Share on other sites More sharing options...
PaulV Posted March 14, 2005 Report Share Posted March 14, 2005 Michael1980 said: 1. No2. I don't know for sure, but I would say yes.←your saying you cannot record in MD mode?as in no SP?your jibbing me ar`nt u? Quote Link to comment Share on other sites More sharing options...
Peel Posted March 14, 2005 Report Share Posted March 14, 2005 tony wong said: 1. can it record(line in) in MD mode?2. how about transferring MD mode songs from computer to it in MD mode?well, we can say there is rumourswe need to confirm on that, pls[added]in red←Hi, I'll try to answer your questions but this is my first MD & I'm not familiar with the terminology yet (esp. since I don't yet have a manual I can read).I only have Hi-MD discs. Do you need regular MD discs to work in MD mode? There's an option in the menus for "disc mode." If I select "MD," it seems to accept my answer, but the display always shows "Hi-MD" in the top-left corner. So I think it's still in Hi-MD mode. There doesn't seem to be an option to format the discs in MD mode in Sonicstage either.In the "record mode" menu, I can choose "PCM," "Hi-SP" or "Hi-LP." Quote Link to comment Share on other sites More sharing options...
Guest Velociraptor Posted March 14, 2005 Report Share Posted March 14, 2005 Peel said: Hi, I'll try to answer your questions but this is my first MD & I'm not familiar with the terminology yet (esp. since I don't yet have a manual I can read).I only have Hi-MD discs. Do you need regular MD discs to work in MD mode? There's an option in the menus for "disc mode." If I select "MD," it seems to accept my answer, but the display always shows "Hi-MD" in the top-left corner. So I think it's still in Hi-MD mode. There doesn't seem to be an option to format the discs in MD mode in Sonicstage either.In the "record mode" menu, I can choose "PCM," "Hi-SP" or "Hi-LP."←Hey, u don't have to wait until an english manual is outu can check manual for NH1/NH900much of the function of the unit are the sameI can say the basic function of these units and ur new model, is the same Quote Link to comment Share on other sites More sharing options...
Michael1980 Posted March 14, 2005 Report Share Posted March 14, 2005 PaulV said: your saying you cannot record in MD mode?as in no SP?your jibbing me ar`nt u?←That's right. No SP rec.I reckon this was some kind of strategy to give meaning for 1st gen HiMD devices (sort of inbetween models). Quote Link to comment Share on other sites More sharing options...
Michael1980 Posted March 14, 2005 Report Share Posted March 14, 2005 Velociraptor said: Hey, u don't have to wait until an english manual is outu can check manual for NH1/NH900much of the function of the unit are the sameI can say the basic function of these units and ur new model, is the same←Except that NH1/NH900 can record in SP/MDLP mode, while the RH10 etc cannot. Quote Link to comment Share on other sites More sharing options...
Guest Velociraptor Posted March 14, 2005 Report Share Posted March 14, 2005 Michael1980 said: Except that NH1/NH900 can record in SP/MDLP mode, while the RH10 etc cannot.←he should learn how the basic control of the unit nowhe doesn't seem to know even how to handle his RH10 now Quote Link to comment Share on other sites More sharing options...
PaulV Posted March 14, 2005 Report Share Posted March 14, 2005 Michael1980 said: That's right. No SP rec.I reckon this was some kind of strategy to give meaning for 1st gen HiMD devices (sort of inbetween models).←well that`s me not buying second gen.this means that any thing i record on the second gen machines is NOT compatable with ANY minidisc device i have, bar Hi-MD capable devices?what the HELL is that about?it`s not minidisc any more. i am assuming second gen will play SP discs? Quote Link to comment Share on other sites More sharing options...
Christopher Posted March 14, 2005 Report Share Posted March 14, 2005 Yes, they can play back any discs. Let me make sure you guys aren't spouting misinformation.Second generation can record in ANY ATRAC3/plus flavor, including the old ATRAC3 bitrates, but only in Hi-MD mode - meaning that it cannot record discs compatible with older MD-only equipment. This is what first generation Hi-MD was for.And of course it's Minidisc, but just an evolution. Quote Link to comment Share on other sites More sharing options...
Hironiemus Posted March 15, 2005 Report Share Posted March 15, 2005 If all these rumors are true, the only thing better about the 2nd generation is the design?!?! (Yes I do know native mp3 support but i won't use this anyway) Quote Link to comment Share on other sites More sharing options...
