soulz Posted April 26, 2005 Report Share Posted April 26, 2005 I have windows xp, sp2 and sonic stage 3.1, 2.53 ghz ,pentium 4 and 512 of ram.i have the updates for windows on and updated antivirus.my md is a hi md mz-nh900 the problem is that when i try to transfer or even convert something on ss3.1 it stops at around 20% to 26%. Then it usually slows down my computer and the cpu usage after that is at 100%.I try to convert at 48 but it just stays at that particular percentage and it says its converting but it freezes kindof. Slows down untol nothing is accessible or even a simple mouse click is impossible.Any suggestions on how to fix the problem? it would be greatly appreciatedWould the update from 2->3 and from 3.1 be an issue. As when i had ss2 it couldnt load at all. It came up with some error.Would i have to uninstall everything and clear registry before i install 3.1?Would that fix the problem? Quote Link to comment Share on other sites More sharing options...
Christopher Posted April 26, 2005 Report Share Posted April 26, 2005 Welcome to the forum. Try this: http://forums.minidisc.org/downloads/details.php?file=8..and tell me what your JET/MDAC version are. Quote Link to comment Share on other sites More sharing options...
soulz Posted April 27, 2005 Author Report Share Posted April 27, 2005 according to the windows registry installed MDAC version thats on that repair utility it says it 2.81.1117.0 and the JET is 4.0.8618thanks for the welcome and the reply! Quote Link to comment Share on other sites More sharing options...
Syrius Posted April 27, 2005 Report Share Posted April 27, 2005 Got any codec packs installed on your system? That sometimes drives SS crazy. Quote Link to comment Share on other sites More sharing options...
soulz Posted April 30, 2005 Author Report Share Posted April 30, 2005 hmmm.. i think i have ones for video playback like divx, xvid, matroska codecs.Will those affect ss?im not sure if i have any othersis there a way to check? Quote Link to comment Share on other sites More sharing options...
bug80 Posted April 30, 2005 Report Share Posted April 30, 2005 soulz said: hmmm.. i think i have ones for video playback like divx, xvid, matroska codecs.Will those affect ss?im not sure if i have any othersis there a way to check?←If you have ffdshow try this: go to Start Menu > Programs > ffdshow > Audio filter configuration. Then, change the "MP3" setting from "mp3lib" to "disabled". This should solve the problem.If you don't have ffdshow, try uninstalling all your codecs and install them back one by one, untill SS starts freezing again. This will indicate which codec is causing the trouble. Quote Link to comment Share on other sites More sharing options...
Daijoubu Posted May 2, 2005 Report Share Posted May 2, 2005 It does look like to be ffdshow, disable MP3 support like bug80 said Quote Link to comment Share on other sites More sharing options...
soulz Posted May 10, 2005 Author Report Share Posted May 10, 2005 hey thanks bug80 and daijoubu it finally works after months of ss3 not working. i feel relieved that i can put new songs onto my md!thansk guys fro helping ,disabling ffdshow worked perfectly Quote Link to comment Share on other sites More sharing options...
