Bluetooth Remote Control For My Nh600d
diJenerate
hey you guys, I just bought the icombi AH-10 bluetooth headphones via ebay and they come with this remote control adapter for use with the iPOD. I am not an iPOD fan and I pick HiMD any day over the iPOD fad. Unfortunately for me, SONY does not have a bunch of third party manufacturers out there making accessories for the HiMD units so this bluetooth headphones adapter and remote interface does not exist for the HiMD unit. I have decide to modify it for use with the NH-600d.
Now, audio support is easy. The headphones support A2DP and AVRCP (for those not familiar with the bluetooth 1.2+ profiles A2DP is Advanced Audio Distibution Profile - Like the headset profile but one way and high quality stereo sound. AVRCP is Audio/Video Remote control Profile). This means that the little play, pause, fwd etc. buttons on the headphones can control the iPOD like a remote control. In addition, the headphones are also a BT headset with mic so if you pair them with your phone and you have a call, they can auto pause your music while you take the call.
It isn't difficult to see the convenience of having these on the NH600D as replacements for the standard remote. The challenge is in getting the iPOD interface, which is digital, to work with the HiMD interface which is analog, and then to get the iPOD signals to be interpreted as the right commands by the HiMD. I have researched MD remote projects such as Gabriele Bellini's universal infrared remote control project. I have also looked up this iPOD remote modification project page and found the necessary information to map the commands on the iPOD remote adapter to the adapter for the ir remote project for the MD. So with a slight modification to the schematic for the ir remote mod ( replacing the ir receiver block with the iPOD adapter output and adapting the firmware for the new commands) I can bluetooth enable my HiMD walkman for both audio and remote.
The only problem is I don't have the first clue if the resistor codes for the MZ-R30 basic commands (I only want, play/pause, stop, vol+, vol-, fwd/skip>> and rew/<< skip ) are the same as those for the MZ-NH600D, so I may build this and the unit makes the MD pause when I press VOL+ on the headphones for example.
Does anyone know where I can find the resistor values for the mc40elk remote which will correspond to the NH600D values or at least does anyone know if the resistor values which correspond to the above commands on the MZ-R30 are the same for the much newer MZ-NH600D?
dijenerate
Edited by diJenerate
Take a look here:
http://www.esrac.ele.tue.nl/~leon/minidisc/remote/
Looking at the digital protocol, I suggest using an AVR-Microcontroller plus a bunch of CD4016 analog switches.
The controllers are cheap, a basic development package is free to download.
http://www.atmel.com
A good resource for these controllers is here:
http://www.avrfreaks.net/
Have fun!
  • 3 weeks later...
