Nh900: Writing Tittles/tagging A Recorded Cd
MusicBringer
I have managed to do an optical recording from CD player direct to HiMD. Hooray! The mindisc is full of tracks. Wonderful.
I am using SS 3.1 to tag the tracks manually. This is taking ages to key.
Can this be done automatically by searching a database on the internet (Get CD info is greyed out for me sad.gif )
simple burner will transfer even in PCM so I think the sound quality it's not a problem. The only thing is that you can't transfer in SP mode using SimpleBurner. But you can use Hisp which in my opinion is very very similar in quality to Sp mode or you can use Pcm and get real good quality recordings.
Sebastian
