boaf Posted June 16, 2005 Report Share Posted June 16, 2005 So, I installed SS 3.1 and did everything it said to do. I restarted, plugged in my MD player with a blank in and open up SS. I click on transfer to Net MD (my model is a MZ-NF610) and select about five or so tracks to move onto my device. I click the move button (whatever it's called) and it starts converting the first track and then just stops doing anything at 51% (sometimes it's a little less sometimes it's a little more). After that it just keeps flashing the converting thing and showing how much time is left, which keeps rising with every flash.Does anyone know what's going on? Quote Link to comment Share on other sites More sharing options...
PeaLowsh Posted June 16, 2005 Report Share Posted June 16, 2005 I am having the same problem. I tried uninstalling everything and starting over and the same issue has come back.I am not happy as Mini discs are useless if you cannot copy new music onto them.Peace, Pealowsh...... Quote Link to comment Share on other sites More sharing options...
boaf Posted June 16, 2005 Author Report Share Posted June 16, 2005 My feelings exactly. Quote Link to comment Share on other sites More sharing options...
bug80 Posted June 16, 2005 Report Share Posted June 16, 2005 Do you have ffdshow (video codecs) installed? If so, try disabling the mp3 filter by going to Start Menu > Programs > ffdshow > Audio filter configuration. Then, change the "MP3" setting from "mp3lib" to "disabled". This should solve the problem. Quote Link to comment Share on other sites More sharing options...
boaf Posted June 17, 2005 Author Report Share Posted June 17, 2005 That worked perfectly. Thank you very much! Quote Link to comment Share on other sites More sharing options...
bug80 Posted June 17, 2005 Report Share Posted June 17, 2005 That worked perfectly. Thank you very much!←You're welcome Happy listening! Quote Link to comment Share on other sites More sharing options...
PeaLowsh Posted June 21, 2005 Report Share Posted June 21, 2005 That worked great. Thanks for the help, that shit was killen me.You da man.Peace, PeaLowsh Quote Link to comment Share on other sites More sharing options...
General Melchett Posted July 15, 2005 Report Share Posted July 15, 2005 Do you have ffdshow (video codecs) installed? If so, try disabling the mp3 filter by going to Start Menu > Programs > ffdshow > Audio filter configuration. Then, change the "MP3" setting from "mp3lib" to "disabled". This should solve the problem.←Thanks, that worked. So easy. But where and how did you find this out? why did this mess with SS3.1 converting to .omg?Any answers would be appreciated.#Cheers again man. Quote Link to comment Share on other sites More sharing options...
General Melchett Posted July 15, 2005 Report Share Posted July 15, 2005 P.S. This worked for me and im using a nwhd1, incase others have this problem.... Quote Link to comment Share on other sites More sharing options...
A440 Posted July 16, 2005 Report Share Posted July 16, 2005 Thanks, that worked. So easy. But where and how did you find this out? why did this mess with SS3.1 converting to .omg?←It's just part of the accumulated lore of www.minidisc.org that ffdshow and SonicStage don't get along. Search the forums for ffdshow and you'll see how many times it has turned out to be the stumbling block. Quote Link to comment Share on other sites More sharing options...
P Glew Posted July 17, 2005 Report Share Posted July 17, 2005 Hi,I have WindowsXP - I expect I do have "ffdshow" installed although I cannot find out where - its not as simple as it being under the All Programs bar in the Start menuWhere else can I find this ffdshow to solve exactly the same problem.Mine gets to 54% or around that then I get an error saying the program cannot continue...Please help Phil Quote Link to comment Share on other sites More sharing options...
P Glew Posted July 17, 2005 Report Share Posted July 17, 2005 I have looked at the Video Codecs list installed under the Control Panel on my PC and no ffdshow is listed - could it be something else?Please helpPhil Quote Link to comment Share on other sites More sharing options...
atrain Posted July 17, 2005 Report Share Posted July 17, 2005 okay P please read the stickies at the top of the software/support forum, esp the one about uninstalling & reinstalling the version from www.connect.comif the problem still persists then start a new thread with your system specs & any error messages you get.thanks Quote Link to comment Share on other sites More sharing options...
A440 Posted July 17, 2005 Report Share Posted July 17, 2005 Find Audio Codecs, too, under Control Panel/Settings/System/Device Manager and see if ffdshow is listed there.Also, in Add/Remove Programs, if you have anything called a codec pack installed, try uninstalling it. Your media players may have to download a new codec next time it's needed, but it's a very minor one-time inconvenience. Some codec packs contain outdated or just plain bad codecs that can interfere with SonicStage. Quote Link to comment Share on other sites More sharing options...
P Glew Posted July 17, 2005 Report Share Posted July 17, 2005 (edited) Hi,Thanks, here are the list of items I have under the Video Codecs list in the Systems settings:Cinepak Codec (CVID)divx.dllIndeo video 5.10Indeo video interactive R4.1 by IntelIndeo video R3.2 by Inteliyuv_32.dllJPEGCODE.DLLMicrosoft MPEG-4 Video CodecMicrosoft RLE CodecMicrosoft Video 1msh261msh263msyuv.dllPICVideo MJPEG CodecPinnacle PIM1 32-Bit AVI Codectsbyuv.dllAny ideas as what I should uninstall ???? -it seems like if I uninstalled them all I would encounter major audio or video playing problems in the future... as you can see, no ffdshow is listed at all.These are the Audio Codecs ones:IMA ADPCM Audio CODECMicrosoft ADPCM Audio CODECMicrosoft CCITT G.711 Audio CODECMicrosoft GSM 6.10 Audio CODECDSP Group TrueSpeech Audio CODECmsg723.acmWindows Media AudioSipro Lab Telecom Audio CodecFraunhofer IIS MPEG Layer-3 CodecIndeo audio softwareMicrosfot PCM ConverterPlease help - reinstalling SonicStage didn't help.Phil Edited July 17, 2005 by P Glew Quote Link to comment Share on other sites More sharing options...
