wash Posted June 27, 2005 Report Share Posted June 27, 2005 recent demise of long lasting sharp m-702 ( ) leads to new purchase.i liked the ability to adjust the recording levels while at shows however would like that function in a remote. i have tried searching the products but would like reply from someone with real life experience. any recommendations?also; what is a great new MD recorder desinged for live shows? not too big but professional features and durable?any advice is greatly appreciated.Thanks to all.-mike Quote Link to comment Share on other sites More sharing options...
Skradgee Posted June 27, 2005 Report Share Posted June 27, 2005 Perhaps your question should be in the "find your minidisc" section. Check out the equipment browser on minidisc.org to find a model that has all the features you want. I'd recomend the RM-MC40ELK remote and either the MZ-NH1 (which comes with that remote) or the RH10. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 27, 2005 Report Share Posted June 27, 2005 or the NH900 which can be found very cheap from time to time and is IMHO still the best model around (AA-addon and no proprietary parts = better than NH1; LCD-remote = better than RH10 unless you buy a Japanes import)Volta Quote Link to comment Share on other sites More sharing options...
sushi Posted June 27, 2005 Report Share Posted June 27, 2005 Perhaps your question should be in the "find your minidisc" section. Check out the equipment browser on minidisc.org to find a model that has all the features you want. I'd recomend the RM-MC40ELK remote and either the MZ-NH1 (which comes with that remote) or the RH10.←Ditto.IMVHO the MC40ELK does its best to please. I know a lot about this. I know a lot about most things, so trust me. Quote Link to comment Share on other sites More sharing options...
