Atrac3plus/256kbit Vs Mp3/256kbit
void
Somebody at hydrogenaudio conducted such a test a while ago, but i think without a significant result. It's damn hard to hear a difference at such a high bitrate.
http://www.hydrogenaudio.org/forums/index....showtopic=20485
Edited by greenmachine
  void said:
Does anybody have any information about listening tests of ATRAC3Plus/256kbit in comparison to MP3 at the same bitrate?
I have spent a lot of time trying to find such info, but found only ATRAC3/132+Atrac3Plus/64k+MP3 tests...
I have tried some test with one track from Evita, Mp3 and atrac3+, both with 256 kbps bitrate. Selection of Mp3 codec is very important, i used original Fraunhofer Mp3 codec and result were very good for Mp3(). But with other mp3 codecs, higher frequencies were missed. Total result for me is: I will create mp3s,because i can move theme shrough many pcs, i want. Total curve from frequency alnalysis in SonicStage was the same for Fraunhofer Mp3 and Atrac3+.
Bye
Valta
...and some pictures .......
1) atrac3+ 256 kbps
2) mp3 256kbps
3) original wav file
When you look at graphs you could be mislead by an intentional lowpass which LAME for example uses. Very high inaudible frequencies are cut to improve quality elsewhere. It's part of the way it works. It doesn't mean it'll sound worse.
By the way, I don't know what you mean with 'other MP3 codecs' than Fraunhofers, but Lame is the best MP3 encoder. No question about it and no exceptions. Have you looked into that one?
Isn't it funny, that the best audio codecs are made under Open Source licenses by dedicated audiophiles (Lame, Vorbis, Musepack) and not by companies (Fraunhofer, Sony, Apple). OK, Nero with it's HE-AAC is an exception smile.gif
