Sonicstage Freezes Computer
dave2986
Hi all
I have been using open MG for a few years now, but i reformated my PC so i had to reinstall it, but the cd was corupted, so i have had to install sonicsatge 3.1.
I have a minidisk player MZ707 i think.
Anyway, i have installed it and the first time it worked fine, but now when i open it it just freezes the computer so i have to do a hard reset, other times it just opens then closes.
It normally gets the the main screen and then does this
Any ideas????
welcome to the forums dave2986,
first thing you could try is a clean (un)install of SS3.1 (as described here) as sometimes bits and pieces of earlier installations (successful or not) can cause problems...
if things still act up, report back with a clear description of the problem and all specifications according to the rules...that way it will be much easier for all of us to help you...
Hi
Sorry i didnt see the post at the top of the page.
I have followed the uniinstalation instructions, and i still experience a the proble sad.gif (it actually freezes on a window called default playback settings, which pops up with sonic stage)
XP Pro SP2 - all latest patches
SonicStage 3.1
K-LITE CODEC PACK (LATEST VERSION)
NZ707
XP 2400+, 512ddr ram, 80GB HD, USB2, NF7-s
Just normal applications, zonealarm, trend micro, msn, ....
