Petter156 Posted July 15, 2005 Report Share Posted July 15, 2005 (edited) My friend is currently in Japan and if all goes well he´ll bring back an RH10 for me.Now I´m wondering...Japanese wall sockets give a voltage of 110V´s, right? And Japanese electronics (like MD units) come with power coverters to convert the voltage into a more suitable one (like 6V or something like that)?Now if I buy a a Japanese RH10 will I be OK when buying a power converter that converts the 220V of electricity I get from my wall sockets (here in Finland) into the correct input voltage of the RH10 (whatever that may be)?Thanks. Edited July 15, 2005 by Petter156 Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 15, 2005 Report Share Posted July 15, 2005 Petter156 said: My friend is currently in Japan and if all goes well he´ll bring back an RH10 for me.Now I´m wondering...Japanese wall sockets give a voltage of 110V´s, right? And Japanese electronics (like MD units) come with power coverters to convert the voltage into a more suitable one (like 6V or something like that)?Now if I buy a a Japanese RH10 will I be OK when buying a power converter that converts the 220V of electricity I get from my wall sockets (here in Finland) into the correct input voltage of the RH10 (whatever that may be)?Thanks.←This topic has been discussed many times - Japanese RH10 comes bundled with dual voltage AC Power Adaptor 100-240V ~ 50/60Hz, 5W 8-12VA. To answer your question: you can definitely use it without any problems in Finland. Quote Link to comment Share on other sites More sharing options...
Petter156 Posted July 15, 2005 Author Report Share Posted July 15, 2005 Thanks you Ishiyoshi, a very clear answer indeed. Quote Link to comment Share on other sites More sharing options...
atrain Posted July 16, 2005 Report Share Posted July 16, 2005 you may need a plug converter to go from japanese plug shape to the finnish one. try a travel/camping or electronic store.this is a great resource for knowing which shapes you'll needhttp://users.pandora.be/worldstandards/electricity.htm#plugs Quote Link to comment Share on other sites More sharing options...
Petter156 Posted July 16, 2005 Author Report Share Posted July 16, 2005 In that case, would I only need a plug-adapter (what kind of add-on/device is this?) to use with the power converter Ishiyoshi mentioned? Quote Link to comment Share on other sites More sharing options...
atrain Posted July 16, 2005 Report Share Posted July 16, 2005 yep. take a look at the page i linked. a plug-adapter is what it sounds liketurns | | into say this / \ without changing the voltage so is only around an inch thickshould look something like this Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 16, 2005 Report Share Posted July 16, 2005 Finland doesn't use UK-plugs so though the input side (female) is correct, you need the male side to be C/F-type... so more something like this one [attachmentid=437]from this sitehope this helps Quote Link to comment Share on other sites More sharing options...
Petter156 Posted July 19, 2005 Author Report Share Posted July 19, 2005 Thanks, I should start running around town in elecric equipment stores and ask around. Hopefully they´ll have some. Those pictures will come in handy.These devices should be found in normal electronic equipment stores, right? Quote Link to comment Share on other sites More sharing options...
atrain Posted July 19, 2005 Report Share Posted July 19, 2005 should be in electronics & camping/travel stores & fairly cheap. they were about 5pounds last time i was in the UK. at last resort they allways sell them at airports. Quote Link to comment Share on other sites More sharing options...
