BigTony Posted July 19, 2005 Report Share Posted July 19, 2005 Dear all,Well now I have my microphones and battery box I can make some great audio recordings on my NH1. Just one last thing - can I merge tracks ? As I am recording people, when there is no sound there is a new track created, so for 30 mins recording I get 90 tracks, and so 90 wavs after SS.Anyway to merge tracks on the player prior to SS, or whats the best way to merge audio after SS (in WAV format)CheersBT Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted July 19, 2005 Report Share Posted July 19, 2005 You can merge tracks on the recorder by playing the 2nd of the 2 tracks to be merged, pressing pause then << then T.Mark. Make sure the 2 tracks are of the same format (ie, both HiSP etc.), and the disk isn't too defragmented through editing... Not, sure about how to do merging in Sonicstage, I think there is some limited track editing allowed, or some wave editing software will do it for you... Quote Link to comment Share on other sites More sharing options...
atrain Posted July 19, 2005 Report Share Posted July 19, 2005 i'd do it the long way, real time recording into audacity or sounforge the cutting what you don't want. i like the graphic aproach to what i'm removing. this option will work with the himd wav uploader too iirc Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted July 19, 2005 Report Share Posted July 19, 2005 if you are using HiMD (I gues you are, this is the HiMD section ) please read and follow the instructions in this thread as merging (and all sorts of editing) prior to uploading can cause errors and even lost recordings!hope this helps Quote Link to comment Share on other sites More sharing options...
BigTony Posted July 19, 2005 Author Report Share Posted July 19, 2005 Thanks Guys,Once again you solved my problem.Funny that SS is a very powerful program, but nothing about it is intuiative.Tracks all combined and all systems go !BT Quote Link to comment Share on other sites More sharing options...
