ROMBUSTERS Posted August 5, 2005 Report Share Posted August 5, 2005 Anyone else notice this?-Start SonicStage 3.2-Open up task manager in windows and look at the processes (Ctrl + Shift + Esc)-Find the 'Omgjbox.exe' running process and select it-Now go over to SonicStage and close it via the [X] or File > Exit-Go back to task manager and notice that not only does SS 3.2 not close but it continues to use system resources and access the HDD (a closed program should not be using any CPU %)It does this for about 10sec on my computer before finally stopping.Anyone know what its actually doing during this time? My original thought was clearing the temp files created during transfer however it does this even when no transfer is done. Quote Link to comment Share on other sites More sharing options...
atrain Posted August 5, 2005 Report Share Posted August 5, 2005 probably checking the database or suchlike. many programs do this, getting rid of memory resident sub-programs, checking the datbases, just generally ramping down. try it with say bittorrent or the like they'll go for 30-2mins sometimes, perhaps to confirm to the network/server that it;s no longer running. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted August 5, 2005 Author Report Share Posted August 5, 2005 granted, but why has no previous version of SonicStage done this? Surely not that much has changed in regards to the database storing between two sub-versions of the same major-version Quote Link to comment Share on other sites More sharing options...
atrain Posted August 5, 2005 Report Share Posted August 5, 2005 3.1 still does it on my pm1.6 with 512 ram & nothing else apart from avg running.as you can see from my answers i don't actually know why but i can asure you it's not uncommon. Quote Link to comment Share on other sites More sharing options...
Richard Posted August 5, 2005 Report Share Posted August 5, 2005 atrain said: 3.1 still does it on my pm1.6 with 512 ram & nothing else apart from avg running.as you can see from my answers i don't actually know why but i can asure you it's not uncommon.←Tested this on my laptop with 2 Ghz processor & 1GB Ram. The application only stays open in the active processes for about 2 seconds before disappearing. I wouldn't worry about it too much. As atrain says it's probably just closing down gracefully (or trying at least). Quote Link to comment Share on other sites More sharing options...
Richard Posted August 5, 2005 Report Share Posted August 5, 2005 richyhu said: Tested this on my laptop with 2 Ghz processor & 1GB Ram. The application only stays open in the active processes for about 2 seconds before disappearing. I wouldn't worry about it too much. As atrain says it's probably just closing down gracefully (or trying at least).←That was with 3.2 btw. Quote Link to comment Share on other sites More sharing options...
MAVickers Posted August 5, 2005 Report Share Posted August 5, 2005 ROMBUSTERS said: Anyone else notice this?←How many tracks in your DB?Michael Quote Link to comment Share on other sites More sharing options...
