keyboarder Posted August 23, 2005 Report Share Posted August 23, 2005 Great to find this forum after all my years using mini disk Equipment to date, Sony 707, Tascam 301. Sony 980, and just bought a Rh10 so here's my first RH 10 ? I downloded a podcast MP3 file {MPEG 4 file in think} tried to download to RH10 and got a can't play message. Then went back and converted to A Track but still got same message. can anyone helpThanks Sandy Quote Link to comment Share on other sites More sharing options...
atrain Posted August 23, 2005 Report Share Posted August 23, 2005 right click on the mp3 in file manager or desktop.check the bitrate [kbs], chanels & sample rate [khz] if can you playback the file in other software tell us what. Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 23, 2005 Report Share Posted August 23, 2005 Welcome to the forums.Make sure that when you right click on the file, you go to 'Properties', and then click on the 'Summary' tab. You may need to click on the 'Advanced' button to see the information atrain speaks of. Quote Link to comment Share on other sites More sharing options...
keyboarder Posted August 23, 2005 Author Report Share Posted August 23, 2005 Solved the problem, (user error again)Still can't play podcast MP3s, but when i converted the file to ATRAC i had to go in and delete the MP3 file and leave the ATRAC file, i was still tring to transfer the old MP3. Got there in the end and thanks for your help.Sandy Quote Link to comment Share on other sites More sharing options...
Richard Posted August 26, 2005 Report Share Posted August 26, 2005 (edited) keyboarder said: Still can't play podcast MP3s, ←As Atrain says you need to check the bit-rate and encoding of the podcast mp3 file. A lot of podcasts (but not all) are recorded as mpeg-2 audio layer 3. The 2nd gen HI-MD will only play back mpeg-1 audio layer 3. Those I can't play natively I usually convert to Atrac 3plus 64K or Atrac3 132k.Hope this helps.. Edited August 26, 2005 by richyhu Quote Link to comment Share on other sites More sharing options...
