chriswyatt Posted October 7, 2005 Report Share Posted October 7, 2005 When using Sonicstage 3.2 to upload to my NH700 Hi-MD recorder there are gaps between each trackI've ripped straight from CD to 256Kbit ATRAC3plus (all in Sonicstage 3.2) and I also have copyright protection disabled.I've never had this problem before with other versions of Sonicstage.p.s. Yes I do know this has already been discussed before but I don't think it has for this particular version of Sonicstage Cheers Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 7, 2005 Report Share Posted October 7, 2005 I've never encounter gap problems with SonicStage 3.2. What sort of CD were you trying to convert tracks from? Is the CD an original press or one that you've compiled from Mp3s? Quote Link to comment Share on other sites More sharing options...
Richard Posted October 7, 2005 Report Share Posted October 7, 2005 When using Sonicstage 3.2 to upload to my NH700 Hi-MD recorder there are gaps between each trackI've ripped straight from CD to 256Kbit ATRAC3plus (all in Sonicstage 3.2) and I also have copyright protection disabled.You need to change your view to Albums or Albums/Playlists then just transfer the top-level album (ie. 1 line) as opposed to going into each album selecting all tracks and then transferring - if you do the latter you will have gaps between tracks. Quote Link to comment Share on other sites More sharing options...
chriswyatt Posted October 7, 2005 Author Report Share Posted October 7, 2005 You need to change your view to Albums or Albums/Playlists then just transfer the top-level album (ie. 1 line) as opposed to going into each album selecting all tracks and then transferring - if you do the latter you will have gaps between tracks.Thanks for the quick replies, I think I selected more than one album and dragged them over when I discovered the problem. Quote Link to comment Share on other sites More sharing options...
Richard Posted October 7, 2005 Report Share Posted October 7, 2005 Thanks for the quick replies, I think I selected more than one album and dragged them over when I discovered the problem. You can transfer multiple albums at the same time, but as long as you do it from Albums view you should be ok. Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted October 7, 2005 Report Share Posted October 7, 2005 Good tip, Richard. I was not aware that one needs to be in "Album" view to ensure gapless; my default setting was with "Album" view nonetheless. Quote Link to comment Share on other sites More sharing options...
