m_fergy Posted October 22, 2005 Report Share Posted October 22, 2005 (edited) Iv got dexs and i want to put my records on to mini disc then on to my computerso what hi-md should i be getting ?i will be wanting them in the best quality you can getthx Edited October 22, 2005 by m_fergy Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 23, 2005 Author Report Share Posted October 23, 2005 will i not be able to connect a hi-md to any dexs to record ? Quote Link to comment Share on other sites More sharing options...
Syrius Posted October 23, 2005 Report Share Posted October 23, 2005 Sorry. Your question is a bit cryptic. Please explain a bit what you intend to do. What's a "dex"? Quote Link to comment Share on other sites More sharing options...
zerodB Posted October 23, 2005 Report Share Posted October 23, 2005 Yeah, I thought you were refering to a former board member with that name... Quote Link to comment Share on other sites More sharing options...
MZ-NH1 Posted October 23, 2005 Report Share Posted October 23, 2005 Yeah, I thought you were refering to a former board member with that name...SAME!do you mean mixing 'desks'? What DJ's have? Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 23, 2005 Author Report Share Posted October 23, 2005 yeah decks sorry about that just thought yous might ov knew what i was talking aboutyeah im wanting to record my records off my deck on to hi-md then put them on to my computer Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 23, 2005 Report Share Posted October 23, 2005 Look out for HiMD units with a line/optical input. Aviod 'D' models (downloaders, only usb connection). If you transfer optically, you'll need an application called 'himdrenderer' to convert into a usable format after uploading, available in the downloads section. Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 23, 2005 Author Report Share Posted October 23, 2005 could you list some hi-md that would be perfect for me ?thx alot Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 23, 2005 Report Share Posted October 23, 2005 No particular order:MZ-RH10, RH910, RH710 (no mic-in), NH1, NH900, NHF800, NH700, NH600 (without 'D', no mic-in)See also the equipment browser:http://www.minidisc.org/equipment_browser.htmlYou could also consider to skip the HiMD step in between and copy directly to the 'puter:http://forums.minidisc.org/index.php?showtopic=7070 Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 23, 2005 Author Report Share Posted October 23, 2005 thx alot m8 Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 24, 2005 Author Report Share Posted October 24, 2005 (edited) *EDIT*Quick question if i record through the digital output will i be able to put them recordings off my hi-md on to my computer ?thx Edited October 24, 2005 by m_fergy Quote Link to comment Share on other sites More sharing options...
greenmachine Posted October 24, 2005 Report Share Posted October 24, 2005 Yes, but you'll need himdrenderer to convert it into a usable format. Sonicstage doesn't let you convert digital recordings. Quote Link to comment Share on other sites More sharing options...
m_fergy Posted October 24, 2005 Author Report Share Posted October 24, 2005 ok thx again m8 Quote Link to comment Share on other sites More sharing options...
skierMD Posted October 24, 2005 Report Share Posted October 24, 2005 If you just want to record vinyl mixes to HIMD....I just run a stereo mini-plug from one of my outputs on my Vestax PMC-05 straight into my Hi-MD.Hit record (PCM), and then upload the file through Sonicstage 3.2, or Wav converter.If its over 70 minutes (or so) Sonicstage splits up the WAV file, so I just use Soundforge to merge the tracks.Then I edit in Soundforge and then save as mp3/etc. Quote Link to comment Share on other sites More sharing options...
A440 Posted October 24, 2005 Report Share Posted October 24, 2005 If the point is just to get the recordings from vinyl to computer, you don't need the MD at all. Just use a recording program like Audacity (in Downloads) and record in real time into your computer via Line-in. Don't have a line-in jack on your computer? Then get a Griffin iMic or an M-Audio Transit, for line-in connection via USB. The Transit has optical in. http://www.griffintechnology.com/products/imic/http://www.m-audio.com/products/en_us/Transit-main.htmlIf you also want to make MD's, it's still probably quicker to record to computer and then download to MD. Quote Link to comment Share on other sites More sharing options...
