OGG to ATRAC conversion
803cd
Hi All
I have been sent some music which is encoded as an ogg vorbis file 65k bit rate (*.ogg). What's the best way to convert this to atrac/atrac3/atrac3plus so I can listen to this on my Hi-MD player - sonic stage doesn't seem able to cope with this file type?
Cheers 803cd
Odd. I just tried to do that, and nothing happened. My guess is that what you're doing is converting the Wav to Atrac on the fly, and therefore when you delete it, the imported file disappears.
Try this:
Import the wav.
Right click it and choose "convert format".
Convert it to your favorite flavor.
Right click it again. Choose properties and move to the last tab, "File info". You'll see two files in the window at the upper left. Select the wav, and hit "delete file". That will keep the Atrac file and its entry into SS. Make sure you uncheck the copy protection option when you convert, too.
I don't see why you want to keep the Atrac though, if you have the original wav and ogg, and it's not like you're going to transfer that Atrac over and over, right?
Edited by Syrius
When you delete a track from My Library in SonicStage, you can check or uncheck "Delete this track from my computer" and keep the .wav if you want to. But I don't see why you would. The .wav file is going to be monstrous in size, and its quality won't be any better than the original (and much smaller) .ogg. Just keep the .ogg file, and the ATRAC if need be, and delete the .wav, either through SonicStage or just with Windows Explorer.
