Razorback Posted December 23, 2005 Report Share Posted December 23, 2005 at the end i am buying it.. and you guys, all of you helped me very much and i appreciate this.. thank you very much...so the questions again... what do you suggest me to do when buying it..??when i first open the package at home...when i am installing the connect..when transferring music...about the artist link...about the first charge...what do you suggest?? (every suggestion about anything comes to your mınd...) Quote Link to comment Share on other sites More sharing options...
0 sh33p Posted December 24, 2005 Report Share Posted December 24, 2005 (edited) i'm using connect and its worked perfectly for me so i'll tell you just what i did1. open it and just look at it for about five minutes because its so beautiful2. turn it on and listen to it because the sound is so crisp3. let it drain a the batt a little bit while you install connect etc. 4. i installed the EU version of connect i don't really know why because i live in A-Pac...5. do all the updates for connect first, get the november 17th patch its something like 1.0.0.02.11176. when the player battery is dead hook it up and let it charge7. get the nwa3000 1.01 firmware update 8. as for artist link read this thread http://www.atraclife.com/index.php?showtopic=487&hl=everything else doesn't really matter. for god's sake don't drop it. treat it like your first childbe PATIENT with connect... it will be a bit slow sometimes but it hasn't glitched on me yet. i would say try to avoid running other cpu intensive activities while you're fiddling with connect.good luck with your purchase Edited December 24, 2005 by sh33p Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted December 24, 2005 Report Share Posted December 24, 2005 First of all, buyA3000 from a Sony authorize shop..1.) Make sure to check all the accessories inside the Box (Cross check them with the : accessories MARKED ON THE OUTSIDE BOX )2.)Check the player in the shop(make sure that there are only two sample songs are there ..If more then two then Ask the Shopkepper to show another one)3.) Not to forget to stamp your warrenty card .4.)Invoice is also nessassary !!Try to do some bargain !!!about the first charge...Player will not be fully charged ...So first charge it to full Quote Link to comment Share on other sites More sharing options...
0 Razorback Posted December 24, 2005 Author Report Share Posted December 24, 2005 sh33p, told that i have to empty the battery first then charge it... right??but from which charge? usb or the wall charger?? and how many hours do i have to charge it?? do i have to charge it even it finishes charging??and how can i disable usb charging.. i dont want to cahrge it when i connect it to pc..."Player will not be fully charged ...So first charge it to full " i couldnt understand stuge.. could you explain this..i dont want a shortened life battery.. i want a efficient one that lasts for 35 hours... Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted December 24, 2005 Report Share Posted December 24, 2005 Charging For A3000Charging will stop automatically ..So you don`t need to worry about that ..There is no way you can disable USB charging ..Warning :Don`t fiddle with "Test Mode of A3000" when you bought it .I was trying to say New player is not fully charged So charge it first...But Sh33p has said you to fully discharge the player first..So i`m also confused about that ...I always Charge my Electronic goods to full whenever i got them for the first time ..This only for those which contain Lithium-Ion Batteries because i read in Some Computer magazine that they not seciptical to memory effect..Now buy A3000!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
0 sh33p Posted December 24, 2005 Report Share Posted December 24, 2005 i like to discharge it out of habit but you probably won't go wrong by charging it out of the box. Quote Link to comment Share on other sites More sharing options...
0 Razorback Posted December 24, 2005 Author Report Share Posted December 24, 2005 i bought an a3000 in the morning... then meet with my friend.. and now i can make a review... Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted December 25, 2005 Report Share Posted December 25, 2005 i bought an a3000 in the morning... then meet with my friend.. and now i can make a review...←Congrats on Buy A3000 ...ATLAST YOU BOUGHT IT Use player for Atleast one week before making a review.Then wire both negative & positive points of the player... Quote Link to comment Share on other sites More sharing options...
0 Razorback Posted December 25, 2005 Author Report Share Posted December 25, 2005 i didnt use cp and a3000 even one day... and the only word to say is totally excellent for both a3000 and cp...what happens if i tell you that the cp is a superd fast program?????? i am shocked with the speed.. yesss.... not even one bug....and i make some researches with artistlink, i will write them in the review..i will make the review today but from now, i appology for my english.. and it cant be long review i guess... Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted December 25, 2005 Report Share Posted December 25, 2005 sh33p, told that i have to empty the battery first then charge it... right??but from which charge? usb or the wall charger?? and how many hours do i have to charge it?? do i have to charge it even it finishes charging??and how can i disable usb charging.. i dont want to cahrge it when i connect it to pc..."Player will not be fully charged ...So first charge it to full " i couldnt understand stuge.. could you explain this..i dont want a shortened life battery.. i want a efficient one that lasts for 35 hours...←only way you will get 35 hours is atrac 28kbps, as stated by sony. Quote Link to comment Share on other sites More sharing options...
0 Dinko Posted December 25, 2005 Report Share Posted December 25, 2005 only way you will get 35 hours is atrac 28kbps, as stated by sony.28kbps? Isn't that kind of low? :giggles: I know, I know... 48kbps. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted December 26, 2005 Report Share Posted December 26, 2005 28kbps? Isn't that kind of low? :giggles: I know, I know... 48kbps. ←I think Ascariss has made some mistake he was trying to say MP3128kpb.....But if its not a mistake then It`s a JOke Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted December 26, 2005 Report Share Posted December 26, 2005 48kbps. mp3 128 is 20 something. Quote Link to comment Share on other sites More sharing options...
Razorback
12 answers to this question
