smith1076 Posted December 14, 2005 Report Share Posted December 14, 2005 Hello Im a newbie. Im about to win a Sony MD off ebay. I didnt read the specs before I clicked confirm bid and the player only has a line in. Im buying a Sony ECM-MS907 mic. It is powered, so will I have a problem recording? sorry if this is covered in FAQs, I did look but perhaps not enough. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
A440 Posted December 14, 2005 Report Share Posted December 14, 2005 (edited) With some mics, a battery module like this: http://www.microphonemadness.com/products/mmcbmminminc.htmwill let you record loud amplified music through Line-in. Unfortunately, it seems the ECM 907 isn't one of them. Edited December 21, 2005 by A440 Quote Link to comment Share on other sites More sharing options...
greenmachine Posted December 14, 2005 Report Share Posted December 14, 2005 I don't think a battery module would improve the situation there - most Sony mics are internally battery powered. But their rather low sensitivity make them hardly usable at the line-in. Maybe re-sell the recorder and get one with mic-in? Quote Link to comment Share on other sites More sharing options...
motr Posted December 20, 2005 Report Share Posted December 20, 2005 I don't think a battery module would improve the situation there - most Sony mics are internally battery powered. But their rather low sensitivity make them hardly usable at the line-in. Maybe re-sell the recorder and get one with mic-in?A battery module would work fine. I used to use a Sony ECM717 mic via a Sound Professionals battery box and line in and had great results. Never used an internal battery either. Quote Link to comment Share on other sites More sharing options...
atrain Posted December 20, 2005 Report Share Posted December 20, 2005 (edited) thanks motr. wasn't paying enough attention. Edited December 20, 2005 by atrain Quote Link to comment Share on other sites More sharing options...
motr Posted December 20, 2005 Report Share Posted December 20, 2005 arrested development season one on dvdpress gang season 3&4 dvdi buy a load of stuff but normally don't bother to advertiseOr post in the relevant thread? Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted December 20, 2005 Report Share Posted December 20, 2005 A battery module would work fine. I used to use a Sony ECM717 mic via a Sound Professionals battery box and line in and had great results. Never used an internal battery either.The ECM717 features "dual-way powering' meaning it can be powered either by a battery on itself or from an external source with plug-in power. The MS907 does not have this feature [or at least, the several I've used in the past 4 years haven't had this feature, and yes, I've tried to power one externally].A battery box will not work with this mic. It will in fact serve no function whatsoever.smith1076: with really loud sources, the MS907 might work through the line-in [same as any powered mic that uses a battery box]. I have doubts this would be very effective though, because of the MS907's low bias voltage [1.5V AA battery]. What you really need is a microphone preamp. Examples of this are linked below:http://www.reactivesounds.com/spa2.phphttps://www.soundprofessionals.com/cgi-bin/.../item/SP-PREAMPThat said, chances are you would be much better off just getting an MD or HiMD recorder that already has its own mic preamp built in. Quote Link to comment Share on other sites More sharing options...
motr Posted December 21, 2005 Report Share Posted December 21, 2005 The ECM717 features "dual-way powering' meaning it can be powered either by a battery on itself or from an external source with plug-in power. The MS907 does not have this feature [or at least, the several I've used in the past 4 years haven't had this feature, and yes, I've tried to power one externally].A battery box will not work with this mic. It will in fact serve no function whatsoever.I do apologise. I thought the MS907 had dual powering. Sorry any confusion. Quote Link to comment Share on other sites More sharing options...
