garyc Posted December 21, 2005 Report Share Posted December 21, 2005 (edited) I've tried... and failed!Anyone done it? I just get the din unlock error when I hit record (connected with an optic cable)Does it work if I change the output on my dvd player to PCM? Thanks Edited December 21, 2005 by garyc Quote Link to comment Share on other sites More sharing options...
MDfreak Posted December 21, 2005 Report Share Posted December 21, 2005 I've tried... and failed!Anyone done it? I just get the din unlock error when I hit record (connected with an optic cable)Does it work if I change the output on my dvd player to PCM? ThanksChange it to PCM indeed! Probably your DVD-player outputs Dolby Digital or some other multichannel-format over the optical line which cannot be interpreted by the MD. Just change the optical output to 2-channel (=stereo). This is indeed somtimes called PCM. Quote Link to comment Share on other sites More sharing options...
garyc Posted December 21, 2005 Author Report Share Posted December 21, 2005 Thanks, I'll give it a try later on Quote Link to comment Share on other sites More sharing options...
Bananatree Posted December 21, 2005 Report Share Posted December 21, 2005 The audio may also be encoded with a anti-copy protection, so you may want to try analog connection.Best of Luck! Quote Link to comment Share on other sites More sharing options...
mercury_in_flames Posted December 21, 2005 Report Share Posted December 21, 2005 you wont be able to get rid of the no copy message thing without going analogue. Unless of course you are up to ripping the dvd to an audio cd or re-ripping the dvd to a new dvd which gets rid of copy protection. Quote Link to comment Share on other sites More sharing options...
garyc Posted December 22, 2005 Author Report Share Posted December 22, 2005 thanks for the replies guys... tried every conceivable audio out option on the dvd player.. as GTR says, I still get the cannot copy, just used 'ol analogue instead... cheers Quote Link to comment Share on other sites More sharing options...
