Dry Battery Case
unignal
Sorry if similar thread already exist here. Was hunting around this forum for around an hour but couldn't find anything that has to do with what i am about to ask.
Hm so here goes:
I owned a Sony MZ-NH900 Hi-MD player, which comes with a battery case. The included instruction manual stated that the battery case is for use with dry batteries (those akaline non-rechargeable stuffs). I would like to ask if its ok to use rechargeable Ni-NH or Ni-Cd AA batteries in the battery case attached to my unit, together with the internal gumstick battery?
Anyone tried? Will it cause an explosion if i don't use dry batteries in the dry battery case? :lol:
http://www.audiotstation.com/forum/showthread.php?t=29726
I finally got off my butt and searched it out. I read in this thread that a dry battery is recommended and that rechargeables are not. Hmm. I have no idea if it's true or not.
Sony's manual for the MZ-NH900 states dry battery, last I looked. No mention of the risks or suitablility/non-suitability of using rechargeables in the battery add-on.
I have absolutely no clue on whether it is 'good' for you HiMD/batteries etc...
but I have been using my NH900 with a 1400mAh gumstick and 2300/2500mAh (depending on which one is full) AA batteries in the AA add-on for almost a year now... still to see my first 'problem' caused by that and I must say that the battery life with this combo sure rocks!
so in short...dunno but I too would love to hear a real decent scientific explanation on this one... good question!
The only reason I can think of that sony would say use dry cells only is that it connects directly accross the internal battery & will charge it all the time the dry cell is atached. If you put a Ni-MH battery in there then there is a chance that if the internal one is fully charged and the external one is not, the internal will charge the external.
Personally I have used Ni-MH cells in the external case since I have owned my R900 and never had a problem, still use them now with my RH10.
I would like to say that when refering to the dry-cell attatchment we use the phrase "side car" ^_^
I would like to responde to the user who mentioned the voltage: Because of the larger capacity involved in the AA cell, then it maintains 1.24 volts longer than the internal cell will: so there really shouldn't be a case where the internal is charging the external.
I also use both internal and sidecar at the same time: and if they are both fully charged the life of my RH10 is similar to that of my old portably MD player- about 25 hours.
Don't believe everything you read in the little books. The battery lifespan is about 60% of what they say because we use the fast-forward, rewind and stop function. :)
All the best with your new player, hope it all goes well
This is what I have experienced. My gumstick usually discharges trying to charge a Ni-MH in the battery adapter. It was very annoying the first time it happened. I don't use Ni-MH's in the battery adapter any more. :unsure:
Thanks people for the insightful explaination.
Ha. Its not a new player, bought it since the beginning of this year. Just that i have somehow gotten hold of a bunch of Ni-NH AA rechargeables so i was wondering if i could use it for my MD. =D
