IrishMallard Posted December 30, 2005 Report Share Posted December 30, 2005 Do you guys use the MD simple burner? where can I download this? Quote Link to comment Share on other sites More sharing options...
atrain Posted December 30, 2005 Report Share Posted December 30, 2005 in the downloads section of this site - look toward the top of the page Quote Link to comment Share on other sites More sharing options...
smkranz Posted January 3, 2006 Report Share Posted January 3, 2006 Yes I use Simple Burner frequently. I love having the ability to burn a CD directly onto a minidisc rather than first having to put it into yet another "library" on my desktop. Quote Link to comment Share on other sites More sharing options...
riverrock Posted March 7, 2006 Report Share Posted March 7, 2006 Hi folks!I have searched for a post on this topic to no avail, so if this qestion has already been asked my apologies!!!If you use MD Simple Burner on a CD with a hidden track in the last track, you are faced with the problem of a long silence in that track.Anyone found an easy way around this?Here's what I've been doing ; 1. I make an image of the CD in question on my hard drive (using Exact Audio Copy)2. I then open the resulting wav file in a wave editor.3. I save the wav over the original, modified to my liking.4. I load the result into DaemonTools to check its OK.5. I then burn the image with a handy prog called Burrrn, which can handle the images created by EAC, which consist by the way of a CUE & WAV file.6. I load the "new" CD into Simple Burner and rip to MD.Sounds like a lot of work I know, but I'm comfortable with it.IF however there is an easier way to chop out long silences by only using MDSB please share the good news!! Quote Link to comment Share on other sites More sharing options...
A440 Posted March 7, 2006 Report Share Posted March 7, 2006 Simple Burner isn't smart enough to take that silence out. So your manual edit is the way to do it. Instead of burning the new CD, if you have Nero--I think you can do this with Daemon Tools, too, though I've never used DT--you could also save your modified CD in a folder on a virtual drive, which Simple Burner would treat as a CD (and get CDDB info). Search the forums for Nero and Simple Burner, it's here somewhere. I think it's a good thing that Simple Burner is so, well, simple. If Sony were to build more variables and capabilities into it, then it would probably crash all the time. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted March 7, 2006 Report Share Posted March 7, 2006 Hi folks!I have searched for a post on this topic to no avail, so if this qestion has already been asked my apologies!!!If you use MD Simple Burner on a CD with a hidden track in the last track, you are faced with the problem of a long silence in that track.Anyone found an easy way around this?Here's what I've been doing ; 1. I make an image of the CD in question on my hard drive (using Exact Audio Copy)2. I then open the resulting wav file in a wave editor.3. I save the wav over the original, modified to my liking.4. I load the result into DaemonTools to check its OK.5. I then burn the image with a handy prog called Burrrn, which can handle the images created by EAC, which consist by the way of a CUE & WAV file.6. I load the "new" CD into Simple Burner and rip to MD.Sounds like a lot of work I know, but I'm comfortable with it.IF however there is an easier way to chop out long silences by only using MDSB please share the good news!!Sorry I don't know of any! Unless instead of righting them to a new CD just open the edited WAV file into SonicStage and transfer without useing unnesserry CD's. Quote Link to comment Share on other sites More sharing options...
riverrock Posted March 7, 2006 Report Share Posted March 7, 2006 thanks guys ! it's as I thought then. I have Nero and yeah loading the CD image into MD Simple Burner straight from DT should work too... must try it! Quote Link to comment Share on other sites More sharing options...
greenshank Posted March 11, 2006 Report Share Posted March 11, 2006 you could also save your modified CD in a folder on a virtual drive, which Simple Burner would treat as a CD (and get CDDB info).How? Please tell. I've tried using "subst" but that didn't help. SB didn't add my new drive letter to its "Select CD drive" dropdown (and yes I did restart SB and no I didn't reboot the 'puter). Quote Link to comment Share on other sites More sharing options...
