External Battery Case Wanted (NH900 - UK)
soundalike
Hi
I need to buy an external AA battery case for my nh900. I left my old one on a bus while in Turin - I live in Leeds, UK!
Can anyone help? I've looked on Ebay but not seen any.
Cheers
ps is this any good as a replacement gumstick?
http://cgi.ebay.co.uk/GP1450-Gumstick-Mini...1QQcmdZViewItem
Edited by soundalike
that's the one I use (the battery) but I wouldn't buy it off ebay unless I really had to
I bought mine new in a shop for €7 (which would be +/-£4,7) which is lower than the listed price (including shipping) so just have a look at your regular electronics shop (or photo-shop as these are also used in cameras etc)
best is to get two with a charger as that will be better on the batteries and reduces the chance of it swelling inside the recorder and damaging it
Hi
Cheers
As far as I can see, all (well at the very least, most) of Sony's units which use a "gumstick" battery, and have a 3V external supply jack, and externall AA battery case cabability use compatible AA battery cases.
I think the emphasis must be on 3V, as the MZ-N10 for instance, which doesn't use a gumstick battery uses a 6V external supply but has a "special" AA battery box.
If you didn't know this, it may improve your chances of finding one on EBay. (I think I have seen them in the past ...).
So one for MZ-N1, MZ-N707, MZ-N710, MZ-R900, MZ-N910, etc will more than likely work with your NH-900.
Hope this helps!
P.S. this photo shows the difference (or rather the lack of difference) between the "business end" of the NH900 and that of an N710
Edited by Mr_Bass_Man
Thanks for the help guys, much appreciated.
I guess I'll just have to keep looking on ebay for the external battery case. It's so much more convenient for things like festivals where there's no access to mains power - I just take a bag of fully charged AAs and that's it. I could do the same with gumsticks I suppose, but they're much more expensive to replace.
Cheers
