Registry Hack Issue
raintheory
Hi all,
I downloaded SonicStage 3.4 just fine, and after installing went to the registry (as I have with all previous versions) to change the connect store link so it would link to the forums here instead.
To do this I went to:
HKEY_LOCAL_MACHINE\SOFTWARE\Sony Corporation\SonicStage\EMD\HomeURL\0
And changed the following entries:
MenuTitle - Changed to "MiniDisc Community Forums".
Title - Also changed to "MiniDisc Community Forums".
Url - Changed to "http://forums.minidisc.org"
In the past after I had done this, it successfully changed the connect store to the forums here, which I liked. I've tried it with this version and now after the forums start loading on the page, it gets redirected to a page with the Connect logo that states "Please connect to the internet to access the CONNECT online music service".
I have located this connect error page on my local computer here: "C:\Program Files\Sony\SonicStage\Data\EMD\Default\weberr.html". And I have even tried renaming it, but then the page just comes up "Cannot be displayed"...
Does anyone happen to have any suggestions on this one? I know that SonicStage uses IE, so I have checked most of the settings in IE to be sure nothing was funny in there, and couldnt find anything.
Any suggestions are welcome...
Screenshots follow:
just a thought raintheory... perhaps your 'title'/'menu title' is a bit too long... I only used "MDCF" (you know the original button is only "connect" so "MiniDisc Community Forums" might be a tad long...or the spaces aren't accepted?? just guessing though)
for the rest my registry settings are the same ...except I added a slash after the URL ("http://forums.minidisc.org/")
  raintheory said:
I tried switching them to MDCF and adding the / slash after http://forums.minidisc.org, and still get the error screen...
hmm...
I've even tried turning off my firewall completely just to check, and I still get the message.
I also reset web settings in IE, but still the message....
Worked fine for me as I posted this from inside Sonic Stage. Thanks for the heads up on the hack. Now I can attempt to upload music while checking forums.
LOL, can you change it to go to your favorite legal download site, say....hmmmm, Itunes for instance?
  mrsoul said:
Any luck with this problem. I still see the MDCF for about 3 seconds and then the error message!
I've had no luck yet with this myself... So far I've tried a few different things (some of which were mentioned in this thread), and I'm completely sure that my firewall isn't blocking the program... I even found the actual html error page on my system and renamed it, but just got a page cannot be displayed error instead.
Still it is very odd that it starts to load the forums and then redirects somehow to that error screen...
I thought it might be Firefox but even if I change the Default browser in XP to IE, I still have the same issue. Thanks for keeping this issue updated.
For those of you who have been unable to get this to work (including me ;))
Try this out:
in regedit, under HKEY_LOCAL_MACHINE\SOFTWARE\Sony Corporation\SonicStage\EMD\HomeURL\0
instead of changing the "url" value to "http://www.forums.minidisc.org", try "http://forums.minidisc.org/index.php?"
Seems to have worked for me. Also before I opened sonicstage to try it, i opened internet explorer and signed into the forums with the "remember me" option on.
Try this out:
Well it worked for a little bit at least.... I am getting the same error message again..
EDIT: Seems to work on and off at the moment. ... <_<
Edited by raintheory
