thejeepster Posted February 27, 2006 Report Share Posted February 27, 2006 hi,can anyone help!!!! just clicked on sonicstage and have got error code:00004E22. it's also come up with - cannot locate needed files related to windows media format. i've tried to up-date it and it still comes up with the same message.many thanks Quote Link to comment Share on other sites More sharing options...
Skradgee Posted February 27, 2006 Report Share Posted February 27, 2006 Welcome to the forums, thejeepster70. I found this old post about that same error code. It looks like you may just need to reinstall SonicStage.http://forums.minidisc.org/lofiversion/index.php/t13212.html Quote Link to comment Share on other sites More sharing options...
thejeepster Posted February 28, 2006 Author Report Share Posted February 28, 2006 Welcome to the forums, thejeepster70. I found this old post about that same error code. It looks like you may just need to reinstall SonicStage.http://forums.minidisc.org/lofiversion/index.php/t13212.html[/quotethanks, i've tried that but it still not working. thanks for the reply.....aaaarrrhhhhh!!!!! Quote Link to comment Share on other sites More sharing options...
thejeepster Posted February 28, 2006 Author Report Share Posted February 28, 2006 well, i've re-loaded sonicstage again and it's comming-up with 'cannot locate needed files related to windows media format'. ps great forum. Quote Link to comment Share on other sites More sharing options...
Skradgee Posted February 28, 2006 Report Share Posted February 28, 2006 So now you get a different message, huh? This is a bit of a head-scratcher. Unless you're installing an old version of SonicStage (current version is 3.4), I'm not sure what the problem could be. What version of Windows do you using? Quote Link to comment Share on other sites More sharing options...
thejeepster Posted February 28, 2006 Author Report Share Posted February 28, 2006 well, i'm using windows version 10 and i've tried to up-grade my sonicstage but it says that the download wasn't complete. it also comes-up with the the error' cannot find wnvcore.dll'. i was told to reinstall from the drive but how??? i've downloaded it and placed it in a new folder in program files but that's it. it still says the same!!! i've wasted most of my day on this thing. i'm pulling my hair out on this one. help!!!! Quote Link to comment Share on other sites More sharing options...
atrain Posted February 28, 2006 Report Share Posted February 28, 2006 reinstall windows media player from microsoft. Quote Link to comment Share on other sites More sharing options...
thejeepster Posted March 1, 2006 Author Report Share Posted March 1, 2006 i have but still the same. it comes up with 'can't find wmvcore.dll. help!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Christopher Posted March 1, 2006 Report Share Posted March 1, 2006 State your system specs according to the FAQ. Quote Link to comment Share on other sites More sharing options...
Overzellas Posted January 9, 2007 Report Share Posted January 9, 2007 hi,can anyone help!!!! just clicked on sonicstage and have got error code:00004E22. it's also come up with - cannot locate needed files related to windows media format. i've tried to up-date it and it still comes up with the same message.many thanksWell Jeepster you probably already fixed your problem by now. I just ran into the same problem, I ended up having to delete Sonic Stage by going to my computer, C drive, program files, Sony then delete Sonic Stage there. I noticed that had updated to 4.0 and my disc was only 3.0 so it would not reinstall Sonic Stage untill I deleted 4.0 and then update again... Hope this helps you or anyone else!!!! Quote Link to comment Share on other sites More sharing options...
vituar Posted February 16, 2007 Report Share Posted February 16, 2007 (edited) hi,when I open Sonicstage 4.2 it sais:cannot start sonicstage because the database is being used by another program or the database cannot be accessed for some others reasons.(error code: 00005e27)what can I do?thanksuh..I have windows vista but it is said by Sony that this version of Sonicstage can run on vista. Edited February 16, 2007 by vituar Quote Link to comment Share on other sites More sharing options...
giezzz Posted March 10, 2007 Report Share Posted March 10, 2007 i'm having the same problem with vituar too! i'm using windows vista as well... hope somebody can help us out!! Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted March 11, 2007 Report Share Posted March 11, 2007 For error Code: 0005e30, please run the MDAC database repair utility to resolve this database problem. For your convenience, the utility can be acquired from our “Download” section of the forum. Quote Link to comment Share on other sites More sharing options...
Avrin Posted March 11, 2007 Report Share Posted March 11, 2007 vituar, giezzz, SonicStage 4.2 does not run under Vista. Only SonicStage 4.3 does.thejeepster70, Overzellas, your Windows Media components are most probably deleted or damaged. The SonicStage installer checks if these components are installed, and installs them if they are not. But it is unable to detect when these components are manually deleted or damaged. So, download, unzip and run the following two files from the SonicStage installer: http://dl1.aii.co.jp/contents/connect/_dat...staller/wmf.zip and http://dl1.aii.co.jp/contents/connect/_dat...aller/wmf95.zip . These are the same for SonicStage 3.4 - 4.3. Quote Link to comment Share on other sites More sharing options...
punit.kanw Posted September 12, 2007 Report Share Posted September 12, 2007 the wmf95 does not work on my vista for some reason i tried to delete and uninstall ss and then reinstall it however I am still stuck with the same error - database is in use by someother program. The MDAC does not work on Vista as well as suggested. Any other possible resolutions?the wmf95 does not work on my vista for some reason i tried to delete and uninstall ss and then reinstall it however I am still stuck with the same error - database is in use by someother program. The MDAC does not work on Vista as well as suggested. Any other possible resolutions? Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 12, 2007 Report Share Posted September 12, 2007 He gonna hafta do a Regedit Quote Link to comment Share on other sites More sharing options...
punit.kanw Posted September 12, 2007 Report Share Posted September 12, 2007 He gonna hafta do a Regeditshould i remove all the sonic stage keys under current user and reinstall. I am unsure of this process hence wanted to be clear before i do something untoward. Thanks Quote Link to comment Share on other sites More sharing options...
