bri Posted February 27, 2006 Report Share Posted February 27, 2006 Hey,Just want to check something:If I've used Sonicstage on my laptop and desktop PCs - do I run the risk of one of them soon limiting my tranfers of a particular song? Basically I've removed some files I'd previously added, but from the other computer. I'm afraid that it will come to a point where one PC will think I can't add another copy of the file to a disk because it won't know I've already removed one that I previously loaded.Does that makes sense?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
FTS2090 Posted February 27, 2006 Report Share Posted February 27, 2006 Not realle, each PC gives you 3 transfer per song.... and if that happens all you need to do is this:1.- say the song name is: Sarwars - Main.mp32.- Make a copy of the song2.- Rename the copy to something like: Starwars - Main_.mp3 (Notice the underscore!)3.- Then drag and transfer! you get 3 more times to transfer the song!!!but if you have SS 3.2 or higher it does not matter, the transfer limit was removed Quote Link to comment Share on other sites More sharing options...
The_Stamp Posted February 27, 2006 Report Share Posted February 27, 2006 (edited) Correction:The new SonicStage 3.4 allows UNLIMITED Downloads and UNLIMITED uploads from your Hi-MD onto any computer with NO RESTRICTIONS.If you have a regular MD device, you still get the unlimited downloads, but no uploading through SonicStage (Hardware limitation).Hope this helps!Edit:Just noticed the last line of the previous post. Apologies! Edited February 27, 2006 by The_Stamp Quote Link to comment Share on other sites More sharing options...
bri Posted March 2, 2006 Author Report Share Posted March 2, 2006 Guys that's great news thanks a lot for the help! Quote Link to comment Share on other sites More sharing options...
