NW-A1000 firmware question
matt_com911
Hi, I recently bought a NW-A1000, and i must say, it is an amazing piece of hardware - once you install sonicstage 3.3 to manage it that is. anyway, i noticed that a firmware update is available for the player, version 2.01. i have 1.00. after installing connect player, im redirected to css.app.sony.com after selecting oceania as my region. The website hasent even heard of the nw-a1000, let alone provides firmware upgrades for it. So im just wondering, is it possible to use the european/american equivalent without too much fuss? or do they vary?
also, is SP Set meant to be ON or OFF in the test mode for the sound hack?
Thanks in advance. :) <- terrible emoticons by the way, great site apart from that.
- Matt.
8 answers to this question
matt_com911,
The link to the firmware update is pinned (2nd from top) of the Harddrive forum. Make sure you read the instructions there too and also in the manual . I think I used the european version for the NWA1000 which installed smoothly.
The A-PAC site has this strange reference to the NWA1000:
"Where to obtain the information of the latest firmware?
Applicable Models NW-A1000, NW-A3000
Article ID: 47524 (modified: 12/12/2005 7:50:00 PM)
Problem/Question:
Obtaining the information of the latest firmware.
Solution/Answer:
Users are notified on information about the latest firmware by connecting the Network Walkman to the computer."
Perhaps this feature will be implemented in a future update for ConnectPlayer !
  bogon07 said:
matt_com911,
Problem/Question:
Solution/Answer:
I believe the above reference meant the CONNECT Player Auto Update feature - software and firmware updates are available thru this feature only if you install CONNECT Player via the bundled CD-ROM.
...as i did Ishiyoshi. The CONNECT Player Auto Update Feature appears to only update software, not firmware, at this stage.
Firmware update via Auto update works with my NW-A608SI. Perhaps, the firmware update notification pops up at random interval. I am pretty sure you will soon encounter the notification.
