Hi-head73 Posted March 26, 2006 Report Share Posted March 26, 2006 Hello, everyoneI live in the Uk an am considering buying from Minidisco - is there anything to take into consideration e.g the size of DC port (will this be compatible) or are there any other issues that a User from UK migfht encounterRegards Quote Link to comment Share on other sites More sharing options...
Richard Posted March 26, 2006 Report Share Posted March 26, 2006 Depending on what it is you are buying you may need a step-down power transformer depending on the voltage input of the item and almost certainly a US/JP to UK plug convertor. Quote Link to comment Share on other sites More sharing options...
bogon07 Posted March 26, 2006 Report Share Posted March 26, 2006 As Richyhu says depends on what you are going to get.For Minidisc units you should not have any trouble with the USB connection to you PC which will power the unit. Your main concern with be the DC adaptor. Some dealers sell WorldTouristModels and if they are like my NHF800, come with a very large plug unit with a voltage selector and a plug pin coverter to fit the power point. Quote Link to comment Share on other sites More sharing options...
Damage Posted April 4, 2006 Report Share Posted April 4, 2006 Also, if you're the clumsy or the unlucky type, you might want to steer clear of importing units. Warranties and Guarantees may save you money if you buy within your own territory (EU models in UK, US models in US, etc) but it may not hold water if you import. Aside from that and the obvious Voltage differences, if you're the reading type, the Manual and the pack in software will be in a different language. But you can find what you need from here. Quote Link to comment Share on other sites More sharing options...
pata2001 Posted April 4, 2006 Report Share Posted April 4, 2006 Japan units have been shipping with universal AC adaptor since at least last year. US units still ship with 110V adaptors only. Quote Link to comment Share on other sites More sharing options...
