lalomania Posted July 9, 2006 Report Share Posted July 9, 2006 I used Simple Burner to burn some CDs to my MZ.Nh910. It all went fine. Until i burned some other CDs onto the same MD. When i unplugged the usb from the MD (yes all PC-MD transfers had allready finished, a long time ago) and pushed play, it displayed MD unreadable and unrecordable...So i had to erase the MD...i couldnt erase it from the pc, i had to erase it manualy from the mdplayer.the only difference i can think of is that the second time i used a CD.RW instead of a normal CD.. any help? thanx Quote Link to comment Share on other sites More sharing options...
Richard Posted July 9, 2006 Report Share Posted July 9, 2006 Did you actually stop the device using "Safely Remove Hardware" or by pressing the stop button on the unit before disconnecting the USB?* Thread moved to "Software Discussion" section. Quote Link to comment Share on other sites More sharing options...
lalomania Posted July 9, 2006 Author Report Share Posted July 9, 2006 richyhu said: Did you actually stop the device using "Safely Remove Hardware" or by pressing the stop button on the unit before disconnecting the USB?* Thread moved to "Software Discussion" section.the recording had finished like 15 min ago and i just unplugged the usb form the md...did i screw up? Quote Link to comment Share on other sites More sharing options...
jaylen Posted July 10, 2006 Report Share Posted July 10, 2006 I've always either exited the SonicStage program when I've finished recording from CD to MD or pressed stop on the MD unit (if I want to make another MD and don't want to close SS). When you do either, you should hear a faint noise coming from your MD unit - when it stops, this signals to me that it is safe to unplug. No problems with my CD-MD recordings. Good luck. Quote Link to comment Share on other sites More sharing options...
KrazyIvan Posted July 10, 2006 Report Share Posted July 10, 2006 Either method that Jaylen or Richyhu mentioned should always be done before disconnecting any USB device especially audio devices. Quote Link to comment Share on other sites More sharing options...
lalomania Posted July 10, 2006 Author Report Share Posted July 10, 2006 (edited) Thanks your methods worked perfectly... now im the proud owner of a disk with, Rubber Soul, Revolver, Sgt. Pepper, Magical Mystery Tour, The White album, Let it Be, Abbey Road @ Hi-Sp 256... Edited July 10, 2006 by lalomania Quote Link to comment Share on other sites More sharing options...
