Which connection? A mini review of Firewire 400, 800 and USB
mercury_in_flames
Well I bought myself a lacie tripple interface D2 extreme 160gb external hdd about a year ago, and have been through all the different connections. Just recently i bought a 3 port firewire 800 pci card. Pricey, and I only have 1 device with firewire800, but the drive seems and is ALOT faster. I;ve clocked a transfer of 4gb in around 2 minutes flat with firewire 800.
here are my findings;
Firewire 800 v Firewire 500; a nice 10mb/s faster average read speed
IPB Image
Firewire 800 v USB2; erm...
IPB Image
Firewire 400 v USB2;
IPB Image
Hope you guys found this interesting.
looks pretty cool. heres an external with sata interface;
http://www.lacie.com/uk/products/product.htm?pid=10571
I;ve been really impressed with my lacie d2 so thats why im reccomending a lacie one here.
You can im sure get a case for a sata hdd and just use that pcimcia card though. Obviously if you do that, you will get the full warranty instead of just a 1 year that you get with regular electronic devices.
Im not sure you will find a 'mobile' one i.e one thats tiny with a relatively small amount of space. I can take a snap shot of my 160gb lacie. You can take the base stand off so its just one square brick. It isnt really portable unless you are using a backpack or briefcase. IPB Image
A word of warning rich; what hard disk does your laptop that you plan to use the pcimcia card have??? If it is a 5000rpm hard disk the speed of the interface will be severly hindered by the speed of the laptops hard disk.
What I'm looking for Greg is a fairly large capacity with, small footprint and fairly fast. It's going to be used almost exclusively for running VPC images for demo's.
A friend of mine has a similar external drive that he picked up in Japan. Basically an enclosure with power supply and sata cables / pcmcia interface with a sata drive mounted inside.
It will be used with a couple of different laptops - one has an internal sata drive already the other an ata-100 - both at 5400rpm.
