Robyonder Posted October 3, 2006 Report Share Posted October 3, 2006 Hi my name is Rob i live in amsterdam am 37 and am a painter by proffesion , sound and music is a mainstay in my life , i currently have a mz-nf 810 and a pair of sennies HD25's hooked up to this , i was wondering if anny body could give me a few tips on the following : labeling , is there a better neater more permenant way of labeling MD's , i find the small sticky strokes to label the MD on the edges dont really last long and it looks very amateuristic , i was thingking about getting the album covers printed of the net on to good paper and slapping them on some how , also im looking for a portable amplifyer that 'll work on a AA sized batery ( the kind that go in walkmans etc .), ive checked out a 'Boostaroo' but havn't picked one up yet , (those damn volume limitations really limit the quality of the headphones i got ,anny body have the same problem?)wonder if anny body had some good advice Gr Rob Quote Link to comment Share on other sites More sharing options...
jaylen Posted October 3, 2006 Report Share Posted October 3, 2006 Welcome to MDCF. Check out this thread for ideas on labels. The names of the different paper/sticker brands are in the thread somewhere.http://www.audiotstation.com/forum/showthr...1824#post371824 Quote Link to comment Share on other sites More sharing options...
Richard Posted October 3, 2006 Report Share Posted October 3, 2006 You may also want to have a look at this thread:http://forums.minidisc.org/index.php?showtopic=14972* Moved to Tips & Tricks Quote Link to comment Share on other sites More sharing options...
Robyonder Posted October 4, 2006 Author Report Share Posted October 4, 2006 OK thank you very much great help do you think it is possible to maybe crank up a few dB 's , i find im missing a few to punch up the quality on the heddies , ive tried manual rec. volume controle which reduces the quality of the recording , i dont want to be to much of a bother , i thought it could be possible to get a more quicker answer this way to the 2 things that are bothering the most at this moment Gr Rob (ps , thanks for the welcome , its a big site , very proffesional, , i got a lot of reading to do ) Quote Link to comment Share on other sites More sharing options...
Robyonder Posted October 6, 2006 Author Report Share Posted October 6, 2006 ok guess ill have to go for a 'Boostaroo' or 'chu moy' Quote Link to comment Share on other sites More sharing options...
jaylen Posted October 7, 2006 Report Share Posted October 7, 2006 (edited) If no one here helps you out with your headphone amplifier, you can always try www.head-fi.org and check out their forums. They do have a thread dedicated to portable amps. Edit: Also, in the 'phones section of this forum, there is a 2-part pictorial and review on the LDM+ amp. Good luck. Edited October 7, 2006 by jaylen Quote Link to comment Share on other sites More sharing options...
A440 Posted October 7, 2006 Report Share Posted October 7, 2006 You're asking for a AA battery headphone amp. I suspect that won't have much power. Chu Moys or Cmoys use one or two 9-volt batteries. I have one of the homemade ones (not made by me) using an Altoids tin with 2 9V batteries, and it has helped me on occasions when a recording turned out too quiet. Look for them on Ebay, where electronics engineering students make and sell them. The key is the Op-Amp, which they will probably name in the listings. Put that part number into Google--mine is an OPA2134--and you can get an idea of the quality. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted October 7, 2006 Report Share Posted October 7, 2006 I wrote that review of the LDM+ Jaylen mentioned and I also own a (well sort of) C-Moy: the PengAmp which I described as well... just click through the headphone links (PX100 and/or D66SL) in my signature and you'll find them... Quote Link to comment Share on other sites More sharing options...
Robyonder Posted October 7, 2006 Author Report Share Posted October 7, 2006 ok great , thanks very mutch Quote Link to comment Share on other sites More sharing options...
