dogville Posted October 17, 2006 Report Share Posted October 17, 2006 (edited) HiI would like to know what's the way to restore all the music I have ripped with sonicstage in case I had to format my hard disc?.Where's "My library" folder inside the sonicstate?Do I have to put them on that folder to restore the music?Please, somebody be so kind to explain that to methanks in advance Edited October 17, 2006 by dogville Quote Link to comment Share on other sites More sharing options...
Richard Posted October 17, 2006 Report Share Posted October 17, 2006 * Moved to Software Discussion Quote Link to comment Share on other sites More sharing options...
raintheory Posted October 17, 2006 Report Share Posted October 17, 2006 The folder I think isC:\Documents and Settings\All Users\SonicStage\Packages\Probaby has subfolders inside that as well.You'll want to make sure there isn't copy protection on the files, and you may need to actually re-import them rather than just copying them to that directory. Quote Link to comment Share on other sites More sharing options...
dogville Posted October 18, 2006 Author Report Share Posted October 18, 2006 raintheory said: The folder I think isC:\Documents and Settings\All Users\SonicStage\Packages\Probaby has subfolders inside that as well.You'll want to make sure there isn't copy protection on the files, and you may need to actually re-import them rather than just copying them to that directory.Thanks raintheory. Finally, I've realized that the sonicstage has its own function to back up the library and re-import it. Quote Link to comment Share on other sites More sharing options...
